Question about i-mate K-jam Smartphone
Help please: WiFi won't turn on
When I press the WiFi icon, it seems as though the device is processing to switch the WiFi on, but it remains off. Can anyone help me with this please?
  • Anonymous May 15, 2009
    i have the same problem here
  • 58 Answers
Try to open the browser and see what connection will ask first... go to settings and erase any infos that are inside... wi-fi must be cleared in all atributes... in the worst case reset the phones factory defaults.. but take out the memory card(if any) and sim card first...
Posted on Feb 12, 2008
My laptop won't connect to wifi
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
Feb 26, 2013 | Computers & Internet
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
May 25, 2012 | ASUS Eee PC 1000HE Netbook
Bluetooth indicator is not lit despite I switch the wireless ON
Confirm the phone number where you would like Verizon to call you. We will call you momentarily to connect you to our automated system. You can also call us at 1 (800) VERIZON (1-800-204-4427).
Apr 13, 2017 | Dell Latitude D830 Notebook
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Hi i bought a dell xps m140 and cant seem to find the wifi switch can you help thanks
Press Fn+F2 ion your keyboard. or else you have to find an icon which is indicating an antenna (As Shown below)
Mar 04, 2011 | Computers & Internet
Pls tell me what is the functional key combination for wireless for my toshiba laptop?
Look for the wifi icon on any of your keyboard's function keys (F1 to F12). The wifi icon looks like a wave or radio signal like ))) or ((( or ((())). When you find that icon, example, in F10, then just press and hold down FN and press F10. This will turn your wifi on.
Also, if your laptop have a mechanical switch, you have to turn it ON first. The mechanical or manual switch is found usually in the sides and can be turned ON or OFF by sliding sideways.
Please post feedback so that I can help you further.
Jun 23, 2010 | Toshiba Satellite A105 Notebook
Where is the wireless switch on a Acer Aspire 5735
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
Nov 17, 2009 | Acer Aspire 5735 Notebook
Wireless internet
Just push in on the wifi light Icon on the top of the laptop. It is a light and a switch. The led light will turn orange when it is off and blue when it is on. That's it. Later gater..
May 12, 2008 | Computers & Internet
WIFI Connection Problem - connects only to EDGE
If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
And simple follow the same steps and revers the process when your out on the go.
Thanks
Oct 15, 2007 | Apple iPhone Smartphone
i-mate K-jam Smartphone Logo
87 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
