Printing from wrong tray
I have a panasonic dp 8045, but when i print a A4 document from word, it gets printed on A3 size paper, i checked all the settings, everything is on auto select, and the settings on the printer is fine.
it doesnt do it with all the documents, i really dont know
  • Neo_guy Jan 24, 2008
    i did all that, it only does it with some documents, completely random?
  • 167 Answers
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Posted on Jan 24, 2008
  • Miroslav Erkic
    Miroslav Erkic Jan 24, 2008
    try to reinstall MS Office!!!
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Apr 30, 2010 | Panasonic DP-8045 Grayscale Copier
E-Studio 3511 will not print a3
check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
Jan 18, 2010 | Toshiba E-Studio 3511 Color Copier
I HAVE A PANASONIC WORKIO 8020, IT SAYS BYPASS A4- HOW DO I FIX THIS?
The computer has sent a A4 size document to the printer and the printer is asking you to put a A4 size piece of paper in the bypass tray so it can print it. It may be an email A4 size that someone has sent you or check the settings in Microsoft Word print or page setup to see if it is set for Letter size, not A4 size.
Dec 01, 2009 | Panasonic Office Equipment & Supplies
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
How to set the paper size in the trays?
most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
Nov 23, 2008 | Panasonic Workio DP-2500E Copier
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
973 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
