Hi. F-1 flashes when there is a primary control failure. This will require you to Replace the machine control assembly. This machine control module has an integrated water pressure transducer on board. This part is damaged, thus, causing the F 1 to appear during the filling process, It is unable to regulate the filling of the tub, due to this damage, present.
You must replace the Machine/Motor Control module, asap. Once replaced, the unit will operate at normal status.
Part Number will be W10189966
