Question about Canon PIXMA MP830 All-In-One InkJet Printer
CANT SEND FAX THRU VOIP LINE
I CAN RECEIVE FAX BUT I CANT SEND FAX THRU VOIP LINE
THANK YOU
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
Posted on Jan 30, 2008
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
Apr 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't receive and send fax
check to see if your phone line is plugged into correct slot marked with an " L " or line on your fax. and that you are getting a dial note from your fax by selecting the speaker button or by connecting a phone into the other slot on your fax marked by a phone and listen for a dial tone.
Thank You,
Mikey
Apr 03, 2008 | Canon FAXPHONE L80 Laser
CANT SEND FAX THRU MY CANON MP830
you need to setup and set data for send and receive to be the same to use the same port!!!
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Brother Printer Fax Machine
The connecting depends on several issues. This cant be said within a few words.
You have to read the manual which explains the very diffrent setting (see chap. fax). You can download the manual here:
www.brother.com (choose your country from landscape, choose your country, choose download&support)
Have a look at the faq, too.
If that doesnt help, plz call brother hotline of your country!
Jan 11, 2008 | Brother Multi-Function Center MFC-240C...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
397 people viewed this question
old marine
old marine
