Question about HP Photosmart 7450 InkJet Printer
Problem with HP 7450 and "Paper Jam"
Couple days ago, I printed something, and when second page started to print, paper stops. I open back door, and remove paper, try to print again, but, agiain was the same. Then, after that, and so on, printer could not bean able to print at all. All time is red flashing and showing message "Paper jam", although tere is no stuc paper. When I turn him off, and them turn on, he try to pull in paper, two times trym,,and then give me a paper jam message.
what could be a problem?
  • 377 Answers
Hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
The print cartridge carriage is stuck.
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
Posted on Mar 16, 2008
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
My HP 2420 had a paper jam. I played around with it and must have cleared the path although I did not see any paper particles fall out. (I did have a jam and figured a small piece must have been left...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Oct 15, 2010 | HP LaserJet 2420 Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315W Color Laser Printer will print only half page
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
I printed a report from the internet a couple of days ago. Now my printer continually prints header information (one line) over and over. It won't stop! If I load the paper tray, it immediately starts...
Take the paper out, go to control panel - printers, open your printer's folder, and choose from the menu Purge all print jobs. If you have some kind of printer status monitor, go there and look for any job that's pending, and try to cancel it. Now turn the printer off, on again, and insert paper - it should be over.
Nov 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
I am having HP Deskjet 3920 Printer. When i try to print any documents, it will show an error message that " The Triclor cartridge is incorrectly installed" , although still it will print color prints...
Hi Anish, Have u checked the printer cartridges installed properly(i.e., Color in color door and black in black door). and also check the cabling between the system and your printer. and put the papers properly. if the problem again persists uninstall the printer driver and install the latest drives which can be downloaded from the net.
May 02, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
HP Photosmart 7450 InkJet Printer Logo
594 people viewed this question
Ben Johnson
