Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44360 thermostat
This morning REC CO error was flashing and the temperature was at 64º -- what is the error message and how to avoid it in the future.
  • patriotpizza Apr 28, 2009
    RE CO flashing on the thermostat and I'm not sure what it means.
  • 52 Answers
The message means the tstat was in recovery mode, I would suggest just disabling this function to prevent it in the future. Remove the tstat from its base and look on the back there will be a recovery switch just slide it to the other setting to disable the feature
Posted on Jan 29, 2008
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
I have a Ruud air handler and i'm trying to use a
The 44360 tstat can be used for single stage Heat pump use only. Unless you are in an environment that has greater than 40 degF outdoor temperatures year-round, you will want to return that tstat and obtain a multi-stage Heat Pump tstat. The standard system is 2-stage......1st stage is Heat Pump Compressor and 2nd stage is the backup electric heat.
Hope this helps. Good Luck. :-)
Feb 21, 2010 | Heating & Cooling
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Oct 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need a user guide/owners manual for a hunter thermostat - model 44360. Any suggestions?
Most manufactures have all their manuals available (for free) online, if you have trouble finding their site, try google or your fav search, good luck, Chuck
Mar 16, 2009 | Hunter Fan Company 7-day programmable...
Hunter 44360 problem
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here:
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
994 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
