Question about Refrigerators
My refrigerator/freezer intermittently gets warm
I have a 7-year old GE side by side refrigerator. The freezer/refrigerator intermittently gets warm. It appears that the compressor does not always come back on when needed for some reason. However, if you manually turn the freezer control down and back up, the compressor always comes right on and everything cools back down just fine. It may go a week or two without a problem, then the problem may occur once or twice a day. The compressor does not seem to get abnormally warm when it runs.
GE Service came out and cleaned the compressor coils, but that did not solve the problem.
  • 770 Answers
GE had a problem with their units I dont see which model you have here but if you pull the unit out and look on the back wall lower right side and see a cover plate with about 10 screws in it ther is a main ctrl board in the and it controls just about everything in your unit There is a relay on the board that controls the compresser as well it maybe sticking at times. The crappy part is you can not just replace the relay you have to replace the whole board.. if this is the case post the model # and i will get you the part# and cost on a replacwement it is something you can do yourself
Posted on Jan 24, 2008
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 04, 2012 | Refrigerators
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
Our side be side ge fridge is giving us a problem...power is ok as lights are on and freezer/ice cube & water dispenser is working ok...but regular fridge side is warming up...it has always been set...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | GE Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Refrigerators Logo
241 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
