Question about Freezers
Fridge compartment drain channel overflows up to twice a day flooding the fridge drain hole appears to be clear i think that the frostfree feature is defrosting to often.as the fridge seems to be starting up every ten mins. help
  • 51 Answers
Check the drain line on the back and under the refrigerator. I think you will find out that it is clogged up.
You didn't give a model number ao I can't tell you where to pinpoint the blockage.
There may be a drip catch at the top of the refrigerator that you can pull out, no tools needed on the drip catch.
Posted on Jan 24, 2008
Fix-ya
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Jul 31, 2014 | Fisher Paykel ActiveSmart Fridge - 17 cu....
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 26, 2008 | Freezers
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
87 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
