Question about Nintendo Game Boy Advance Console
Cartridge problem when i drop my cartridge so many times when i played it, it dont starts
  • ken ken Mar 11, 2008
    it still doesn't working it is a gundam seed battle assault but my gameboy is still working
  • jeromy thotland
    jeromy thotland May 11, 2010
    Does the game not start or the gameboy itself? Which gameboy model is it? Have you tried other games?
  • 106 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-25
Posted on Jul 23, 2009
    New Friend:
  • 85 Answers
Open your cartridge then clean it with alcohol
Posted on Jan 31, 2008
Mobigo 2 cartridges won't play
My son's is doing the same thing just emailed vtech as well
Jan 25, 2013 | Vtech MobiGo Touch Learning System - Blue
I did the maintanence cleaning and print test and it still prints out lines in the pictures
It might be running out of ink.
If cartridges are new then inkjet's heads are clogged. You can do the following to unclogged the heads, which might be located where the cartridges are plug into or on the cartridges itself.
Run 5-8 times the cleaning process from software. If doesn't solve.
Locate the heads an apply 5-7 drops of alcohol into heads and start cleaning process with installed cartridges again.
If the printhead is in the cartridge you can soak with hot water and also used alcohol drops.
Always run the self cleaning software utility.
Then try with new cartridge.
God Bless You!
Feb 05, 2011 | Brother MFC 420CN All-In-One InkJet...
My SX600FW Epson Stylus will not print black even with new toners?
We took ours to a local repairer who used a special program to blast the heads. We had tried head cleaning ourselves and this didnt work. It has had to go back two or three times but it does work for several week after.
May 05, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Is there a way to trick the printer into thinking the ink cartridge is full? I put in a new cartridge and it registers at about 75% every time.
The ink measuring things are ESTIMATES at best. They count the number of times the jets throw drops and the approximate volume of ink that is consumed versus what the cartridge holds. Run them till the print just starts shows degrading. Use refill kits but don't overfill the cartridge.
Nov 28, 2009 | Epson PictureMate (C11C556001) InkJet...
I dont want to sync my remote each time i play the wii how can this be resolved?
a lot of times the controller starts acting strange once the battery starts to get low. (and if you drop it!)
so if you know someone borrow their WII controller and test it. if the controller works fine then your other controller is probably damaged. a new WII controller is about $40 so you could either buy a new one or get a used one from wherever like craigslist or something.
Nov 13, 2009 | Nintendo Wii Console
During vinyl play the sound will drop Numark TTUSB
sounds like the needle is worn down...try to replace the needle.....the buzzing sound often comes from open groung connections...that can come from the cartridge itself to the jacks on the back of the unit....bad ground and buzzing is normal for turntables and will also dramatically affect your sound level because the buzz or groung fault is higher than the sound being picked up by the needle.....open grounds can be checked with a meter set to continuity....to check for continuos line feed with no breaks in the lines.....if you find a broken line ...then that's your problem....it is a very simple repair....if the ground problem is in the cartridge...replace the cartridge which comes with a new needle as well...it's cheaper to buy it that way in stead of just bying a needle...if the ground fault is anywhere after the cartridge...then it's just a mater of replacing or repairing the line..again..very cheap repair....also...if the cartridge just clips on to the shell, sometimes it makes bad connections there too....that can just be cleaned with a little sand paper and it will work again....good luck
silvio
Jul 08, 2009 | Numark ttUSB Turntable
Everytime i play a game,like 2 minutes later it freezes
try putting rubing alcohol on a q-tip and cleaning the contacts of the game cartridge. you dont need a lot, if that doesnt work you may have dropped your ds too many times
Jun 30, 2009 | Nintendo DS Lite Console
I have a pioneer deh-p7800mp and i dont know how insert the disc
there is a slot behind the screen when you push open the screen should drop down. put the cd into that slot when you do the screen will go back up. push open again the screen will drop and your cd will eject automatically.
Mar 25, 2009 | Pioneer DEH-P7800MP
Printing Problem
You should mention the model name, then its easy for us to assist you. Anyway in general, refilling the cartridge can cause many problem including the one you faced now. What you shoul do is, u buy a new cartridge. In future if you need to refill dont do it yourself, ask help from the shop you buy it.
1. Its not safe for your printer health in long term, if u insist to i recommend you 2-3 times only, and ask the computer shop teach you how to refill it or you can ask them to refill it for you.
2.you can get at a computer shop.
3. don't expose to heat, open the cartridges only when ready to be replace, dont wash it, drop it, bend it.
May 12, 2008 | Office Equipment & Supplies
Sound drops out
dear you must upgrade sound card driver from owner website
and dont forget update DirectX to lastet version
wait
Dec 24, 2007 | Asrock K7S41GX Motherboard
Nintendo Game Boy Advance Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
