Question about Epson Aculaser C1100 Printer
Poor Print Quality on Epson Aculaser C1100N
Any black printing that my C1100N deals with now is of a really bad grainy quality. If I send the same text document but for instance as blue or red, it prints perfectly. I thought this might be a K Toner issue but I have now tried three toners all new and stored perfectly but the problem still happens. I've changed the Photoconductor Unit but to no avail. Black printing is terrible it looks grainy and more grey than black. Is there a fuser or a part that controls the black fusing only that may be at fault? It seems a mystery. I'm stuck without the printer so could really use some good clear advice on how I can fix this.
Thanks in advance.
  • 2 more comments
  • reddoten Feb 19, 2008
    Inky,
    Thanks for getting back with a solution. I didn't realise each colour had its own dev unit. I thought it was all handled through the photocunductor. Would this also account for a lot of black toner being used and spilled within the printer. The toner count shows a dramatic drop in Black Toner after realistically only about 20 pages have gone through the printer to test it.
    Thanks for any help you can give with this. It is a real headache!
    Kind regards,
    Justin
  • reddoten Feb 20, 2008
    Inky,
    You're a star.
    Cheers,
    Justin
  • maxamine Feb 20, 2008
    I have a white vertical line 1.5" left of center. I have cleaned the print head per instructions several times, changed the k toner. Will a photoconductor fix this? Please help.
  • CoolTanTom Aug 22, 2008
    I've got trouble with blurry printing down the left hand side of the page. It's as if the text or whatever has slipped down and repeated itself in grey. We recently installed recycyled print cartridges and a new photoconductor - is it that that has caused the problem. It's particulary bad on glossy labels which is a real shame because i'm trying to do a mail out today too...
    Tom
  • Epson Master
  • 705 Answers
Sounds like the black dev unit is worn out. Easy enough to change yourself if it is out of warranty. If it is in warranty get Epson to do it for you.
Posted on Feb 18, 2008
  • Inky Fingers
    Inky Fingers Feb 19, 2008
    Each colour has its own dev. Open the top cover, take out the PCU and look at the coloured part of the carousel where you see the toner on the roller - that is the dev unit.
    The spill inside the machine is fairly normal as most users have trouble seating the carts properly due to Epson's (somewhat half arsed) design. It is too easy to leave the cart with the right side not fully seated but still be able to open the toner cart. Obviously once the carousel turns it scatters toner everywhere.
    This often accounts for blank strips on the print as the toner falls onto the laser lens.
    Toner usage is like, how long is a piece of string. The original carts shipped with the printer are (very) low capacity ones. The manufacturer makes money from consumables not printers, so they give you just enough to get you going then they run out.
    I'm not picking on Epson - they all do it. A faulty dev could certainly account for increased toner usage.
    Bear in mind if the K dev is going now, the others will not be that far behind. If you do approx half as much colour as mono then the CMY will be about half worn out now.
    If the machine is in warranty - get Epson out to it. If it is out of warranty, get a quote to buy all 4 devs then a quote for a new C1100 ( you do not need to buy the N version as two screws will allow you to change a C1100 to a C1100N) and see wether it is worth fixing or buying a new one and keeping the old for spares. Then if you decide it's worth fixing, buy a service manual to fit the devs yourself. If you have a No2 philips screwdriver and know how it works, you should be able to change a dev in about 20 minutes. I do them in about 4 minutes each.
    Hope this is helpful to you.
6ya staff
SOURCE:
Toner is full but printing quality is poor
Depends on what type of poor quality you have. Are there repeating defects? A bad fuser, bad photoconductor drum will both cause problems, even if the toner is full.
Aug 29, 2015 | Epson Aculaser Mx14
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
Cant print
you'll need to have the jam removed before you can print.
May 20, 2009 | Epson AcuLaser C1100N Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Epson r230
hello babu,
the problem is not with the printer, problem is with your general knowledge, to print on cd/dvd surface means you have to stick the sticker (cd label sticker) on the cd, then put the cd on the printer to print.
ok
bye bye
hope u will soon understand......
Jun 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Nov 18, 2007 | Epson Aculaser C1100 Printer
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Epson Aculaser C1100 Printer Logo
1,989 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
