Zanussi Washing machine
Programme for synthetics, temperature 40degrees, 900 spin all selected and lighting up on panel. time of 1.16 is also displayed. the door is closed yet the light is not on and the start/pause button also wont light. The washing programme wont start, the reset button when selected only displays error. Have tried: unplugging machine, emptying filter, checking door is closed properly and nothing is caught in door seal. Any more suggestions?
  • 1 more comment
  • tazcork Jan 24, 2008
    Zanussi washing machine
    additional info:
    when any of the buttons are pressed ERR is displayed on the display panel. its as if the machine isnt recognising that the door is closed and pressing the start button has no effect. pressing the reset button changes nothing either. ERR is displayed no matter what button is pressed.
  • HanBat Feb 25, 2008
    I have the same problem too! My machine is stuck on "ERR" no matter what i do.
    what can i do??
  • prem mathew May 11, 2010
    What is the error shown?
When any of the buttons are pressed ERR is displayed.
Posted on Jan 24, 2008
  • 1,294 Answers
Try some WD40 on the door switch.
Posted on Jan 25, 2008
Washing machine fs1255w does not respond to the programme switch. the end light flashes 9 times, every time
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 07, 2008 | Zanussi Washing Machines
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Washing curtians
Select a delicate or wool programme, this will give you a cool wash and a slow spin.
Feb 03, 2010 | Zanussi F1045W Front Load Washer
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
