Question about Sony DVP-NC875V Multi-disc DVD Player
Dvd player problem
The picture is constantly moving diagonally across the screen. Any ideas?
1st make sure the connections on the dvd player and device dvd connects to are correct.
ie av cables red white for audio and yellow for video. this is for standard display.Component video uses different color cbles and is for high quality digital display. or for low quality hd display.
if it still moving diagnally then make sure progressive scan is turned to off. that solves 90 percent of the problems. let me know how it is setup for further support
Posted on Dec 11, 2008
DEAR
CHECK YOUR AUDIO VIDEO COARD BY REPLACING IT
CHECH AV CONNECTOR OF YOUR TV WAS LOOSE
CHECK MPEG BOARD OF YOUR DVD PLAYER WAS DEFCTED
THANK YOU
Posted on Jan 25, 2008
Problem with my Magnavox DVD player, DP100MW8, picture dark and lines across the screen
Hi, if the lines are diagonal sounds like it is set to progressive scan mode-which means if there is not a switch on back saying P/S and interlaced then you need to connect to T.V. with component video inputs ( indicated by red,green,and blue colored R.C.A. plug inputs) and Pan and Scan capable-then in menu setting select interlaced picture output. hope this was of use, good luck prodzilla
Mar 30, 2011 | Televison & Video
I have Diagonal lines moving across the screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 15, 2009 | Toshiba 51H83 51" Rear Projection...
I get sound but no picture from my DVD player.
Check if you don´t activate the progresive scan function or video sistem
Apr 23, 2009 | Samsung DVD-V5500 DVD Player/VCR
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
John
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Diagonal lines on upper 1/3 of screen
It sounds like the dmd board may be defective but you can try rebooting the set and see if it makes the picture any better...
1 - Turn on the Tv.
2 - Press & Hold the up arrow key on the remote and then press the power button on the front of the Tv.
3 - Tv will reset & reboot
If the picture is the same it's probably the dmd board which is part of the "B" block assembly and I don't believe they're sold separately. The "B" block is about $1100.00 dollars.
Hope this helps!
Bill
Apr 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Horrible picture after moving
Sounds like your convergence chip has gone bad.
Jan 25, 2008 | Toshiba 50HX81 50" Rear Projection...
Diagnal Interference Lines
the diagonal lines represent some low frequency interference (close to the supply frequency - 60 hz). Try to keep the unit away from other appliances, especially the left back zone - where the tuner is. Also, you have to do some experiments on the cable connections: disconnect other cable devices (internet modem, home phone, other tv/tuners), one of them might inject these signals into the cable. Keep me posted
Aug 25, 2006 | Toshiba DR4 DVD Recorder
Sony DVP-NC875V Multi-disc DVD Player Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
