Question about Kenwood KDC-7024 CD Player
Security When i turn my engine on i need to put in the code but say if i just pop in the petrol station then i come to turn back on you have to keep putting the code in it is really anoying any one help?
It is likely that your radio has been wired incorrectly, generally speaking there are two different wires that need wiring, an ignition wire, and an permanent wire, I guess you have both wired to the ignition hence when you turn off the car it forgets the code. If you check the wiring and make sure the permanent wire is connected straight to the fuse box and not the ignition it should resolve your issue.
Hope this helps
Simon
Posted on Jan 24, 2008
Where is the gas cap on the Toyota voxy which can cause engine light on the dashboard?
The gas cap( petrol cap) is where you fill the tank at a gas ( petrol station
If it has not been put back on correctly it affects the EVAP system and that will put the light on
Feb 25, 2016 | Toyota Cars & Trucks
The engine indicator light on the dash board keeps is showing but it not go off after the engine is turned on and running. What is it indicating?
IT IS A CHECK ENGINE LITE IT IS TELLING YOU THAT YOU HAVE A PROBLEM WITH THE MOTOR TAKE IT AND HAVE A COMPUTER HOOKED TO IT AND IT WILL TELL YOU WHAT IS WRONG
Jun 24, 2015 | 1998 Toyota Corolla Station
Please Help! I brought a vw golf 2.0 petrol gti, 2000 plate. when I turn ignition on it says "service now" however today whilst driving on two separate occasions, the batter light came on, power died on...
what are the diagnostic codes? if they are manufacturer codes they should be 5 digits, if they are generated using a non manufacturer scan tool they will be 5 digits beginning with a letter, in your case most likely P for powertrain then four numbers ex. p0121, you may also have U codes or B codes which are basically body and communication codes. Scan the codes, write em down, clear them again, and see which ones come back. The better scan tool the more info you can extract from the vehicle. Keep an eye on the check engine light, immobiliser/security lights etc. Could be a key/programming/relearn issue. Im here if you need me.
Regards,
-Tim Messina
Mar 26, 2015 | 2000 Volkswagen Golf
I have a gardentec 52cc chainsaw which wont start. I have a spark and fuel getting thro.
Hi you mentioned that you defo getting spark is that from spark plug against side of engine, try this put a very small amount 50/50 pet oil inside cylinder head through sparky entrance screw spark plug back in try it now if it pops abit no matter after 5 times you have a carb prob float faulty jets blocked, blocked feed line, Advise you need a bowl petrol no smoking wash carb in it blow clean jets put back only when all is clean check petrol tube sometimes they go hard and block up make sure petrol is getting to cylinder head, hopes this helps
Feb 17, 2014 | Garden
Put new start on my transit came out petrol station and start wont turn engine over
If the starter spins but does not crank the engine, the problem could be the solenoid or bendix gear of the starter, or the flywheel could have some teeth missing.
Jan 27, 2013 | Cars & Trucks
How do i put diesel into my ford mondeo from a diesel container when it has a security feature which prevents syphoning and therefore will not take a plastic nozzle??
You will find the diesel pump at the petrol station have slim nozzles that release the safety feature and the other petrol types a wider nozzle thus preventing you from putting the incorrect fuel in your tank. Your spare tyre compartment should contain a special funnel to use that releases the safety catch for you to fill from a can.
Mar 27, 2012 | 2007 Ford Mondeo 2.0
I ran out of petrol, only just made it to the petrol station and now a light is on the dash. Its orange and has a picture of an engine on it
That is the check engine light. A drive to a garage with a code reader will help you figure out why it is on. One of your pals may have a code reader.
Feb 04, 2011 | Mitsubishi Eclipse Cars & Trucks
Daewoo matiz 1999 immobiliser code fault car will not start
Daewoo Matiz 2002 (UK version,immobiliser problem,no spark and i changed everything like coil...)
Oct 19, 2008 | Vehicle Parts & Accessories
My sercuity code
What it is? You "just" need the security code for this player. If you have the code, you can put it in and the player should work. A manual how to input the code is in the faqs of Blaupunkt. I remember, that you have to press the first station button as often as the first digit of the code says. The same with station button two and digit two and so on.
By the way, I also need the code. I bought my car used and I didn't get the code with the car. But the player is still working without code.
Feb 17, 2008 | Blaupunkt San Remo CD32 CD Player
Kenwood KDC-7024 CD Player Logo
121 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
