Question about Nokia 6300 Cellular Phone
My phone won't ring
On my phone profile it states it is active but my phone won't ring.
Help!
  • 281 Answers
Do you have an icon on the phone similar to the one that you see when your phone is in silent mode? A striked out music note code? If it is there check the incoming call alert in your profile personalization setting, it should be ringing or ascending.
Posted on Jan 25, 2008
Go to PROFILES go to NORMAL go to screen that promps (activate- customize-timed) select CUSTOMIZED go to ALERT FOR ,select ALL CALLS then press DONE .....you must press done or none of the changes take ........I had the same problem and this action solved it...
Posted on Feb 02, 2008
    Sniper:
  • 111 Answers
Maybe the buzzer's broken or something..try changing it...
Posted on Jan 27, 2008
2 Suggested Answers
jaffi
  • 8 Answers
SOURCE: my phone won't ring
>>> if u already fell down of u r mobile means please try to change the ringer
>>> otherwise try by the softwares...
Posted on Feb 16, 2008
My phone won't ring, only vibrate...help!
Without more specific information as to what model phone you have, I can only provide you with general instructions. Under 'settings' in your phone menu, you should see an option called 'profiles'. Highlight that and click on it, and you should be presented with several different profiles, such as outdoor, meeting, silent, etc. Once there, select one of them and click on it, then 'edit profile'. You'll have a host of different options now, and at least one of them should deal with "notification", where you can change it to 'vibrate and ring' or 'ring only'. Again, I'm not sure of the exact wording, but you'll need to change it to something besides 'vibrate' or 'silent'. When you're finished, click 'done' or some such, then 'apply profile' from the next screen. Make sure you apply the same profile name as the one you just finished editing. Hope this helps! :)
Aug 28, 2012 | Cell Phones
Tip
Phone is not ringing
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
    • Signal strength is indicated by the signal indicators at the left side of the phone's display,
    • These indicators move up as the strength of the signal increases and down as the signal decreases.
    • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
on Sep 13, 2010 | Cell Phones
Phone ring tone volume has gone lowe
Locate where 'profiles' is on your phone.
Select the profile you want to use,
Then select, 'personalise',
You would see the 'ringing volume' option,
Select it, then increase the volume to your desired taste.
Make sure you select 'save', or 'done', whichever is applicable to your phone, when you are done.
Then select 'activate', to activate that profile.
Hope that helps?
Success.
May 13, 2011 | Cell Phones
How can i activate my ringtone
hi....
please follow these steps to activate you ring tone.
1.open menu--->profile---->select the profile which you are using currently
2.After selecting the profile---->select personalise from it.
3.there is an option in it,Incoming call alert
4.In that you have to select ringing to activate the ring tone.
5.There is an option called as Ringing tone,you can select which ever ring tone you want and save the changes.
thanx
Jul 18, 2010 | Nokia N73 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Nokia 6300 has stopped ringing anyone any ideas?
o.k. does it vibrate?
have you dropped it?
You may have accidentally put it on silent mode:
HERE IS HOW TO CHECK YOUR TONES OR PROFILE:
10. Settings
Profiles
Your phone has various setting groups called profiles, which you can customize with
ringing tones for different events and environments.
Select Menu > Settings > Profiles, the desired profile, and from the following
options:
● Activate — to activate the selected profile
● Personalise — to change the profile settings
● Timed — to set the profile to be active until an end time. When the time set for the
profile expires, the previous profile that was not timed becomes active.
Themes
A theme contains elements for personalizing your phone.
Select Menu > Settings > Themes and from the following options:
● Select theme — Open the Themes folder, and select a theme.
● Theme downloads — Open a list of links to download more themes.
Tones
You can change the tone settings of the selected active profile.
Select Menu > Settings > Tones. You can find the same settings in the Profiles menu.
If you select the highest ringing
all this can be found in your manual:
here is a link to the manual for: nokia 6300
please remember to rate my help if it was of assistance it helps me too.
Mar 26, 2010 | Nokia 6300 Cellular Phone
My phone is not ringing
You have either turned off your ringing by choosing the quiet profile or you have changed the settings for your defaul profile. Either way what you can do is go to menu and choose profiles. You will have an Active sign by your profile. If you have the quiet profile as Active than you should change it to Normal.
If you click on advanced in the profiles section you can change the audi settings for your active profile.
best regards
Mar 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Get phone to ring
its simple just go in settings then profiles then the profile which u hav activated then personalise n then change the tone n volume u want then save it n then activate the profile
Apr 18, 2008 | Cell Phones
My phone won't ring
Feb 16, 2008 | Nokia 6215i Cellular Phone
Nokia 6300 Cellular Phone Logo
2,233 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
