Question about HP Officejet 5610 All-In-One InkJet Printer
HP 5600 All in One
Was printing well without difficluties.but with a refilled cartridge.  a mis conection went with my power supply then the next morning I refixed the cartridge.  The HP 5610 then started USB device not recognized. upto now. Have already  tested it on other computers but the response is the same.
Any help will be valuable.
  • immom Feb 17, 2008
    I changed cartridges and then printed the alignment paper. It printed. After that my 5600 HP printer would not recognize my computer's command to print. Nothing happens. It will copy, however, so I know the cartridges work.
  • Anonymous Feb 17, 2008
    i have tried to fihd software to solve my problem making the printer work and recieve information from hp media center pc
  • 167 Answers
Try with another USB cable!!! Its no matter is the cartridges OEM or refilled!!!
Posted on Jan 24, 2008
Do refillable cartridges cause HP 3650 printer to not print????????
Get new ink cartridges. If they sit that long without being used the ink will dry out in the print head part of the cartridge and clog the very small holes. The clogs are inside the cartridge so wiping the outside will not clear the blockage. In the future if you have to leave the unit without it being used for over about a week you should remove the ink carts and put them in a sealed zip lock bag to prevent them from drying out.
Mar 28, 2013 | HP DeskJet 3650 InkJet Printer
HP Printers
maybe an ic chips or an hp toner bias plate that contact the toner cartridge
Feb 19, 2013 | HP Office Equipment & Supplies
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or fails to function at all (i.e. blinking ink lights on Deskjet 5000, 5100, 5500, 5600 or 5800 series printers) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video:
Also verify that the cover interlock switch (at top-right side of printer) is closing properly - you may need to place a thick shim (1/4 inch by 1 inch) into the door switch port to enable printer to properly energize (I would check this first). This Deskjet printer series is known to have a top cover closing issue (the top covers warp over time unfortunately).
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site:
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the cartridge nozzle plate (refer to video):
Jun 19, 2012 | HP Office Equipment & Supplies
I got a refilled hp 27 cartridge refilled at a local office supply store and installed it into my hp deskjet 3740. It prints in "normal" mode but the text is faded. I used the calibrate and clean...
It is probably the "refilled" cartridges. Return them and buy a know good brand. Office Depot's brand seems to work fine in my HP printers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | HP DeskJet 3740 InkJet Printer
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Hp 818 print cartridge show incompatible after refill, or show problem with print cartidge. how to use them after refill without any problem
Whoever is doing refill for you should know that HP cartridges have electronic sensors that measure level of ink. They should have procedure with which they either reset the counter or "fool" the cartridge to work after refill.
Basically, you can't do anything yourself.
May 03, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet 3820 - have refilled the cartridge and pc wont print
Clean the contacts on the carriage with piece of cotton and then clean the contacts on the cartridge with rubber and try again. If this not help replace the cartridge.
Oct 25, 2008 | Apple HP DeskJet 3820 InkJet Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Epson stylus cx4800 won't print
Hi, reason we sell epson printers are they are the cheapest to run, but they do get alot of problems with the print heads, if you change from using refill ink kits to compatible ink cartridges you would not have to reset the chip each time, otherwise you will have to change to a more expensive to run printer like the HP, or Lexmark, lexmark is the most expensive for cartridges but it has the print heads built into the cartridge and not the printer itsself, epson only have the chip on the cartridge.
You can use the refill kits on most HP & Lexmark without having to reset the cartridge all you need to do is refill it.
but for every 3 for example you may have to buy a new cartridge which will be more expensive, ie if you get lines through your print, as the print head will probably get blocked on cartrdige.
Happy New Year
Dec 10, 2007 | Epson Stylus CX4800 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
372 people viewed this question
Ben Johnson
