MP3 and Digital Media Players
Problem for MP3 and Digital Media Players
Generic problem for all MP3 and Digital Media Players
Accurian mp3 player problems
By tessling1 on Jan 24, 2008
i have an accurian mp3 player (42-198 is the # on it) when i first plugged it into the computer to do the "4 hour charge", it said it was charging, but then when i turned it on, it would do the load screen, say "goodbye" and shut off... so i replugged it in, which took 15 tries to get it to connect... now it's frozen on a screen with a full green battery, a white little computer and a bar with a green dot in the middle... i've tried to hit the power button for 15 seconds like it said to do in the manual, but it won't work... it just stays on that screen... what do i do?
Same Problem
Mar 15, 2009
-   my accurian mp3 wont leve the loadding screen-   Guest
Mar 09, 2009
-   My accurian won't turn on. I can't charge, listen to music, or anything -   mweinhart
Jan 29, 2009
-   el prolema es que enciende y pronto se apaga solo dice. device/detabase error.connect pc and format the device as fat-   cruz_anna01
Jan 19, 2009
-   ipod accurian 42-198 ,el problema es que no puedo formatearlo y si se conecta a la computadora,este problema es desde el pasado 22/12/2008...alguien puede ayudarme-   Guest
Jan 06, 2009
-   my accurian has the sames problen.-   Guest
Best Solution
posted on Feb 03, 2009
Very Helpful)
pistitan
Rank: Apprentice
Rating: 100%, 4 votes
Hello Guys ... I got it solved !!! here's what I did:
1- Go to www.mymusix.com
2- clik on FAQ, then on 43-198
3- find the solution for this question :Q: When I turn on my player it says 'Error, connect to PC and use Device Manager to repair'., and click on link
4- Follow the instructions
If after following all the instructions, you still can't see the device on windows, click on downloads, then on 42-198, then download the mpt utility and run it, the do the above steps again
hpe this helps
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jan 31, 2008
Helpful)
Lalani
Rank: Apprentice
Rating: 95%, 8 votes
It is charging i have one to!! once u think it is charged take it off the USB cord
Was this helpful?
Yes
No
Solution #3
posted on Mar 15, 2008
Helpful)
razz007
Rank: Apprentice
Rating: 92%, 2 votes
I had issues with mine where I would plug into the usb and nothing. not charging not showing up on computer, it was like it wasn't plugged in at all. I emailed tech support. they told me to send it in (Radio Shack had none in stock and did not know when more would come in so could not return it for a new one). I sent tech support the mp3 player and in about a week or two I received a new one but now this one has the problem where I at first I was able to load songs to it but now it won't let load or delete songs from the player. All I get is a device is busy or disconnected message. So now I'm back to emailing tech support.
From there website:
"Our goal is to provide the highest quality products, the best competitive prices, and long-term services to our customers. We have the skill, the technical know-how, the professionalism and the comprehensive manufacturing facilities that build on our reputation as digital audio pioneer.....Superior quality, Innovative and unique design, Competitive prices, Prompt delivery, Excellent post-sales services are our keys to success."
I agree they do have competitive prices and their customer service and tech support is very good but quality of product does seem questionable especially with all the problems that these particular mp3 players have been having. Hopefully they can find a way to fix these bugs.
Best solution would be contact their tech support:
support@mymusix.com
Was this helpful?
Yes
No
Solution #4
posted on Jun 24, 2008
Somewhat Helpful)
savemyday
Rank: Apprentice
Rating: 79%, 4 votes
charging the player:
i've had a battery problem once.. but i realized that i did not completely turn it off so it was not charging correctly... every electronic item charges faster when its off..
ok so, you know when you leave it on to play and after the cycle is over the music stops? after a while in that "stop music" stage the mp3 player looks turned off... (it's like it's hibernating). before you recharge it always always turn it on and turn it off. that fixes the problem right away. I've had mine for over six months and no problems!!!
as for not getting it to pop up on the computer:
just go to the "my computer" icon and it should have it's own icon there under "other" and you'll see the little icon. must i say.. click on it?
to download music on it:
you can't just copy and paste the music you want into the music folder... the mp3 player will separate and organize it for you..
you should have windows media player.. pop in whatever cd and ripped it into your media library.. then you should sync it with your mp3 player.
if you are downloading music from a site.. don't create any folders on the mp3 player (i know if would let you but DON'T).. just copy and paste the music into the main part of the folder (it's the window that opens after you click on " internal storage device"...
oook... that's all i see up there. have fun w/ da music playa cuz i am.
i'm so glad i didn't get an expensive apple.. i'm not going to pay $100 more just to customize the color!!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jun 24, 2009
Not Rated)
haheha
Rank: Apprentice
Rating: 0%, 0 votes
are you sure its not on lock? If not try holding the play/pause button with the menu button.
Was this helpful?
Yes
No
Solution #6
posted on Apr 21, 2009
Not Rated)
doray
Rank: Apprentice
Rating: 0%, 0 votes
I have an portable video mp3, the problem is the battery so I change it. When I tried still it cant charge, pls say the solution as soon as possible.
Was this helpful?
Yes
No
Solution #7
posted on Feb 07, 2009
Not Rated)
paajnub
Rank: Apprentice
Rating: 0%, 0 votes
for mine's this shows on the screen n i'm currently trying to fix it too...
device/database
error. Connect to
PC and format the
device as FAT.
you can trying going to this website and follow the instructions.
http://mymusix.mmvoice.com/products/audio/42-198/42198recoveryonlyfaq.html
Was this helpful?
Yes
No
Solution #8
posted on Jan 16, 2009
Not Rated)
malikyusra
Rank: Apprentice
Rating: 0%, 0 votes
when i charge it while it is charging it will not turn on
Was this helpful?
Yes
No
Solution #9
posted on Jul 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hmm... what im thinking is do what the 3rd guy said but i tryied it with taking of PD Meida Converter and putting my music in the "My Music" folder it should work i've just thought it as a thoery...
Solution #10
posted on Mar 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
all you have to do is plug it back in to the computer for a w2hile then take it off the ubs cord it should be fine ne ways i have one that wont let me delete the songs that it came with off and some that i put on there and finally only let me delete half but now it wont let me put ne on
Solution #11
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
send me the software demonteic3@yahoo.com
Solution #12
posted on Jan 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
take it back to radio shack for a new one.
Popular Solutions for MP3 and Digital Media Players
Questions and Unsolved Problems for MP3 and Digital Media Players
Answer
I want a touch screen mp3 player for a 12 yr old and do not want to spend more than $50.00.
Answer
i want to buy a new dumbassss
Answer
I have a VOICE file on my if--390t 256Mb MP3 player which I am trying to transfer to computer.... (More)
Answer
I got my iriver an year ago and it worked good but yesterday I got a microSD card and wanted to see... (More)
19 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 06, 2009
My accurian mp3 has the same problem and i don't know what to do. when i connect it to the usb it turn off. it dent's charge. i don't know if i should take it to radio shack to see if they can fix it. i bough guarantee for one year but now it expired.
Comment by Guest, posted on Jan 04, 2009
it turns on but it wont connect to the computer and wont charge at all
Comment by cakebaker, posted on Dec 28, 2008
got it for christmas last year. didn't use it a lot but when i did it worked fine. wanted to take it on a trip this past summer. loaded some more music on in. the next day, it wouldn't turn on! didn't take it on the trip cuz it wasn't working. tried it when i got back. still didn't work. tried it again a couple months ago and it turned back on but had deleted all my music! i was pissed! today i re-loaded the music back on but when i unplugged it from my computer it wouldn't turn on again! i'm so frustrated! what do i do???
Comment by obxchick, posted on Dec 02, 2008
it will not come on it just says good bye...
Comment by moonie14, posted on Oct 28, 2008
i am have changed my mp3 and then i truned it off 2 times and then i wanted to listen to it again it died. but then i put it on the changer and it charged with a half battery. then it happens all over again. but today it started to go to a no blak llight then a light it was strange. What do i do i just got it last christmass and i didn't use it over the summer, never droped it! what should i do???
Comment by Arl2008, posted on Oct 20, 2008
I HAVE THE SAME PROBLEM BUT THAT IS NOT CHARGE AT ALL
Comment by drag673, posted on Oct 16, 2008
well i found out that If you tap the middle of the speaker and back tag It will allow you to turn it on but now it says that it takes 5mb
Comment by Guest, posted on Aug 22, 2008
it won't turn on.
Comment by cabo38sailor, posted on Aug 14, 2008
I bought 2 as gifts for my nieces at a gathering one told me hers never worked would turn itself off and would not hold a charge,the second one worked well for 6 months then just quit and will not turn on both sets were pricey and no service available ,radio shack stated my problem ,no Accurian company to follow up with .not only is the product shoddy there is no way to fix them and Radio Shack was not helpful at all. I agree with i pod purchase and avoiding Radio Shack whom it seams is no longer a dependable company
Comment by Guest, posted on Aug 06, 2008
The screen shows a computer and the battery at half strength. Now my computer does not recgonize the device? It says the device has a malfunction and says replace the device. Which I have un plugged a dozen times. Oh Accurian does not have any direct customer service. Then Radio Shack wants me to pay to ship this thing to them and get it back in 4-6 weeks at my cost. I will take it back and get an i pod that is easy to use and have good customer service.
Comment by Guest, posted on Jun 25, 2008
on and off dont work
Comment by heresgerald, posted on Jun 17, 2008
mine turns on with welcome screen goes to this white screen and says good bye and turns off ever since i got this it has not work vary well it is **** it will always be ****
help me
Comment by rider27, posted on Jun 01, 2008
Juan. Accurian CAT.NO.42-198 MP3 PLAYER. I disconected from my computer and now it doesn't turn on. It is totally dead. No wellcome screen at all. I purchase in radio shack. I don't know if the problem is because I up grade my computer windows media player.
Comment by Jenna21, posted on Feb 27, 2008
My Accurian mp3 player has been working fine (even though it is challenging to get it turned off and back on sometimes) until today. I charged it last night, tried to turn it on this morning and it wouldn't come on. I kept trying to turn it on about 15 or so times and it finally came on, but it froze on the Accurian screen. So, I turn it back off, turn it back on and now it says I only have one song saved (when I actually have downloaded and played 65 plus songs previously). I can only get it to acknowledge/play one song. I've attempted turning it off and on a few times, but still only get one song. Any suggestions?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For MP3 and Digital Media Players:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
