Question about LG X-Note LM50 Notebook
Screen hinge too loose
Hi there
My LG LS 70 screen hinges are too loose and the screen won't assume an upright position. How can I tighten it a little bit? Thanks
  • 593 Answers
A the base of the screen you may see some scews that cover access panels, open them up and you can tighten the little nut that tensions the hinge. I had a laptop that was shaky and I tightened the hinges and it was OK after that.
Posted on Jan 24, 2008
My computer screen won't stay in place
Laptop hinges cannot be tighten. To fix your display hinges, they need to be replaced.
Check out these WEB sites for details on how to replace the hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Jul 22, 2012 | Computers & Internet
Loose screen hinges on lg laptop.
Yes, get on eBay and purchase LCD Hinges
Apr 20, 2012 | Computers & Internet
Loose hing on Gateway c140xl
Faulty hinges cannot be adjusted or tightened. If the the mounting screws are loose then these can be tightened.
These WEB site hace detailed instructions on replacing faulty hinges.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
Feb 16, 2012 | Gateway Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
I have toshiba satellite A100 laptop just off warranty period.The screen dosent work when moved from a particular position around 90degree .It will stop working even if moved by 2degrees from the...
One of 2 things offhand. #1 Tighten the Hinge screws, many systems ground the LCD thru the hinges and if they get loose, lose some connectivity. #2 Reseat the LCD cable and inspect the cable where it passes thru the hinge assy for chafing and broken wires
Mar 11, 2010 | Toshiba Satellite A135-S2276 Notebook
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Monitor lid will not stay in position.
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't know which is the problem until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Aug 01, 2008 | Acer Aspire 5100 Notebook
Laptop screen will not stay upright
You may be able to tighten the hinges, but more than like you will have to replace them
Jul 01, 2008 | Dell Inspiron E1405 Notebook
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
LG X-Note LM50 Notebook Logo
364 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
