Question about Acer TravelMate 2300 Notebook
Wireless Connection my note book connects and disconnects every five minutes
  • Ntombizethu Zondo
    Ntombizethu Zondo Jan 24, 2008
    my Acer notebook won`t connects and disconnect to the wireless connection
  • Anonymous Feb 10, 2009
    wi-fi
    Problem Solver:
  • 17 Answers
Lemmor is correct and i suggest that you should find a perfect spot where you can have a stable connection.
Posted on Jan 25, 2008
  • 749 Answers
The wireless network distance maybe too far for its range. Or your location is blocked by a thick wall... Find a good spot for your computing
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Linksys WRT120N Router
I've a Edimax 7284WnA Wireless N150 ADSL/+2 Modem Router. The problem is, whenever I use its wifi functionality with my sony laptop, the connection keeps disconnecting. Please note that the internet...
You are right, if your laptop has no issues except in your home, your laptop is not the problem. You should read the "Communication Failures" section of my tip entitled "Understanding Wireless Networks". You can read it here. You should troubleshoot this starting with the obvious... Are you in Range? Is there a device causing interference (cordless phones, other access points, microwaves)? If there are other WiFi Access Points in your range, verify that they are on a different channel than your router (you can do this with a free WiFi Scanner called "NetStumbler" or "InSSIDer"). If you follow my advice given in the article, and you still have issues, there is a possibility of the router's transmitter/receiver starting to fail.
I hope this helps,
Livingmentor
Feb 03, 2011 | Edimax BR-6216Mg Wireless Router...
Can not get on internet with note book don't know what code to enter
1. Yes, but you have either have to have access on the router or if it is a free connection you will have to scan for that router to gain access and click on the router that is open to you if you have a wireless card in the Sylvania G net book which should have a wireless card built into the mother board. It will take you to set up your net book for wireless connectivity.
2. If you are trying to get connection through wireless router via a home network the administrator will have to allow your net book to have access, that is he will have to give you permission to connect with either a MAC address or an IP ( internet Protocol address).
Sep 17, 2010 | Sylvania G-Netbook
I get the following message when I try to open the setup on a Cisco http://192.168.1.1/ "is not available" I am trying to add a ROKU Netflix player via wireless
Follow these steps one by one and check:
1. Disconnect the Router from the Computer and connect it again.
2. Reboot/Restart the Router by turning it OFF and ON after one minute.
3. Check the connecting wire is properly connected.
4. Open the command prompt and ping 192.168.1.1
5. Try changing the connecting Wire.
6. Try to login using different Computer.
7. Reset the Router by pressing the reset button and configure it again.
NOTE: Always try to login to a Router using a Wired connection not using a Wireless connection.
Good Luck!!!!!!!!!!!!!!!
Sep 16, 2009 | Linksys WRT160N Wireless Router
My wireless internet connection is getting interrupted every few minutes
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
  2. Wireless settings of the router are still set to default.
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
  • Manufacturers suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other Linksys routers within your network range. Manufacturers suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | Computers & Internet
HP dv6139 loses Inet connection after 5 minutes (both ethernet & router)
Most probably it's the router's fault, if you have one. I've seen many cheap routers randomly loosing wireless connection with their computer clients. Try with another router. One possible solution: upgrade the router's firmware.
Oct 23, 2008 | Computers & Internet
Can not connect
It is possible that your windows update messed up the Linksys drivers. If your pc is xp, download the latest drivers from www.linksys.com/download. uninstall the wpc54g on the add/remove programs.
if using XP, reinstall drivers only, no need to install the linksys software. This would be best if you install the drivers manually. After this you will be using only the WINDOWS UTILITY for your wireless connection.
Feb 27, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Wireless router disconnects every 5 minutes...
I had the same problem with my dlink (not wireless). Try going to their website and configure the router. It worked to me.
Dec 07, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
