To reset Convergence
How do we reset convergence it has 3 simply instructions but we are unable to find the focus button the remote or convergence button?????? As the T.V screen color has gone dark blue and not sure why????
Model Hisence HDT4366G/HDT5066G
Any help would be much appreciated
Bea
  • olds98 May 18, 2009
    I have a rca r52wh74 and the color gun is off and its shows 3d, how do i fix it
  • Larry  Dillon
    Larry Dillon May 11, 2010
    What type and model number is this TV Set?
    President:
  • 3,130 Answers
I did not read the question all the way. I still need to know the make of the TV set. If the picture is all blue, that's not an indication that the convergence needs to be reset. That sounds more like a problem with the video driver unless you have no sound. I really need a little more info on the set to say for sure.
Posted on Jan 25, 2008
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Hello i have a sony KP-46WT510 model 45" TV, and
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc
Feb 18, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My rear projection tv 51MP392H/17 has a blurred red shadow that makes it look kind of like watching a 3d movie without the glasses. for a while we could turn it off and back on and it would reset the...
Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. It still can be repaired.
Using your original remote go-to the settings menu then goto the convergence section. Try to adjust the red and then the blue convergence. You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix Reply
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. If you have never done this before we would advise calling a technician or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.Thanks! hope you rate my response
Feb 02, 2011 | Philips Magnavox 51MP392H Rear Projection...
Hello, my tv looks 3d
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 12, 2010 | Akai PTH5498 54" Rear Projection...
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
How do i set convergance on my53uwx10B
you can go in through the back of the tv to set the focus you should be able to converge the tv from the remote.if not i would call a service tech and have them come and reset it for you.
Jan 21, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Red is out of convergence
I would stay away from that repair man. That model has just one Convergence IC number STK393-110 and it takes about 45 minutes from start to finish to remove the old IC and install the new one. You can get the replacement IC at the following link and they provide free instalation instructions with pictures so you can do the repair yourself for less than 30.00. Heres the link. You need just 1 STK393-110 Convergence IC they have free shipping as well.
http://servicemanuals.vstore.ca/
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
