Question about Aiwa AWP-ZX7 CD Shelf System
Aiwa mini-component it has low level of sound even it reaches the maximum level of volume control.but,if you use the aux input with other cd player with its own volume control my aiwa mini-component sounds loud. I think it has a low audio signal passing thru the main amp..or the main amp has leak?main amp IC is: STK490-110. how can i fix it to have a better gain level. before,level 20 of volume control is good enough...but now,level 20 is too poor in terms of audio level. anyone know how to fix this problem???
  • 1,512 Answers
Gidday mate... it does sound like a failure in the audio output stage. I suggest that you first check the speakers for short circuits as a fault here will produce a similar symptom you described. Check that you have the correct DC conditions about the STK, such as main power supply. Check all resistors that are in proximity to the STK, particularly lower value ones. Look also for shorted or dry capacitors about the output stages. Most of the audio signal path amplification is inside the STK and generally only a few millivolts of audio are provided to the input pins(usually the outermost pins). I have looked online for a data sheet on the chip that may be of help to you, but have not yet been able to find one. If the unit has soft touch electronically switched input selectors or electronic attenuator to the vol control, either of these IC,s may be faulty also. I am happy to keep going with this to help you fix it if you want. Give me a hoy back in here and I will :)
Posted on Jan 25, 2008
  • 107 Answers
I had a problem same as this before. I just put a jumper from a transistor to transistor. ( its been almost a year & half, ) I was checking at the drivers (input from aux, cd, tape, fm/am output signal) with my tester and sudenly I conncected my testprodes to 2 transistors and came out with a loud . which is before it was like chattering.
if the STK have a leakage then all your input signals are having same problems.
I guess its in the preamp section. give it a try to check and resolder some part.
DEAR
I UNDER STAN YOUR PROBLEAM VERY WELL,
PL CHECK FOLLOWING POINT'S
CHECK MUTE SIGNAL PATH WITH YOUR MAIN AMPLIFIER
CHECK MAIN AMPLIFIER STK BY REPLACING IT
CHECK MAIN SPEAKER'S.
CHECK BIASING CIRCUIT WITH STK INPUT
CHECK HEAD PHONE CONNECTOR BECAUSE IT GIVES OUT PUT TO MAIN AMP.
THANK YOU
Aux in volume is low on aiwa stereo
Use the forward keys when in AUX , it gives u a 5 step volume level .
I have tried it and it works.
Feb 08, 2014 | Aiwa Audio Players & Recorders
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
How to raise the AUX sensitivity level
The problem may be insufficient output from the turntable cartridge or a mismatch between the cartridge and the AUX/D-IN input.
Oct 19, 2017 | Aiwa XR-C303RW Shelf System
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
Volume problem with the AUX input using iPod
Do you have the ipod turned up too? Whats happening is the alpine is getting to low of a foltage signal.
Jul 30, 2008 | Alpine CDA-9825 CD Player
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Open Questions:
Aiwa AWP-ZX7 CD Shelf System Logo
334 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
