Question about Sony Ericsson P1i
P1i problem with my Wlan
I cant access my internet thru my wlan. its giving me an ip address of 169.XXx.xxxx. but other gadgets with wifi tech can have access to my internet. im using a seimen wireless mode. ty
  • 209 Answers
Re: P1i problem with my Wlan
If you are using the winxp operating system try to run the network wizard from the control panel
Posted on Jan 24, 2008
0 characters
3 Points
How do I run a wireless (WLAN)connection on my nokia 9300?
A built in wifi simply means that your gadget is equipped with the ability to communicate wirelessly. Yes,it will automatically connect to your internet connection , provided it is able to detect the presence of a wifiaccess point such as a wireless router. These access points are quite common in public places that are considered as wifi hotspots
Mar 03, 2011 | Nokia 9300 Handheld
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Wlan in sony p1i
i have sony ericsson p1i and im trying to connect wlan...then when i connected,i cant browse. it always appear
Jun 19, 2009 | Sony Ericsson P1i
How to access internet using wifi for g900 sony ericsson which line needed password or good show me step by step thx
1.Activate wlan
2.Scan -search for WIFI
3.Those without lock u can connect to(the others need password more often a wep KEY)
4.Some of them requir to pay (so it is not locked but in order to have internet access you need to pay)
5.connect (if the wifi use dhcp it sends to your mobile IP address + gateway+ dns)
6.You check your ip anf if it is something like 192.168.x.x it should be ok try to open internet from the menu.
Good luck.
Jun 05, 2009 | Sony Ericsson G900 Smartphone
Acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
Aug 26, 2008 | Acer n30 Pocket PC
Wifi ad-hoc for p1i
the SMC adaptr for P1i is 802.11b or 802.11b+802.11g
Jul 18, 2008 | Sony Ericsson P1i
Can't open web pages in WLAN mode
Had the same problem but some how fixed it. WLAN connected blue ball displayed but the page didn't open.. well this is what i did and it worked...
I went to my router and opened the section for wireless access point or the access control. I dint turn on the access control mine is still an open network but the was a list displaying available access cards connected to the that my laptop and my P1i showed and i added them to the access control list( even though i didn't check the box to turn access control..wiered) but it worked and im browsing.. now when i check the connected devices shows the P1i tooo.. soo the fix is in the router...none other solutions abt router worked except this one AND i use operamini and not the default browser.. .. am I A GENIUS?
Jul 16, 2008 | Sony Ericsson P1i
P1 wifi configuration
Hello laserxp,
for this time i want to tell you that i am not very familiar with the P1 wifi, however as my experience on the some wifi connection i only read the usermanual manual of the unit connecting to the internet.
please show me a picture and the model of the wifi so that i can figure out your problems.
PS: pls donot rate me if the solution donot solve the issue.
Jun 27, 2008 | Sony Ericsson P1i
WIFI for Toshiba E750
If u use a WLAN access point, you should: 1. configure your wlan router to allow internet 2. choose "WORK" in the network connections configuration dialogs. and maybe you will have to configure the proxy server too.
Sep 11, 2005 | Toshiba e750 Pocket PC
Internet connection at my e830
To configure the Wireless connection you can use the Wifi connection wizard or setup the connection manually. I hope that you have checked your workgroup too. Also you should check if your IP settings are the same at the router and PDA (dynamic and static IP)! If you have some another device connected to the router remember them when you setup the PDA connection! In the end the MAC address of the PDA WLAN card must be saved in the router!
Sep 08, 2005 | Toshiba e830 Pocket PC
Sony Ericsson P1i Logo
163 people viewed this question
Top Sony Ericsson PDAs Experts
David Payne
David Payne
Are you a Sony Ericsson PDA Expert? Answer questions, earn points and help others
