Question about Jenn-Air JCB2059G Bottom Freezer Refrigerator
Freezer drawer handle loose...how do I tighten screws?
The handle is loose on my freezer drawer. How do I tighten the screw? Thanks
    Genius:
  • 2,985 Answers
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Posted on Jan 24, 2008
Freezer handle falls off on one side , kenmore elite - pull drawer freezer
Mine does that too. I've simply accepted the fact the the screw holding the handle on just loosens over time. Periodically, when I feel the handle becoming loose, I tighten it with an allen wrench and go on.
Feb 21, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Loose handle
bottom of handle is a screw hidden behind a square little sticker thing. use a small screwdriver to pry it out. take out screw and then push handle upwards and it will come off a clip which you can now tighten. then snap top secti0on of handle back onto clip and then lower screw secures it.
Nov 09, 2009 | Freezers
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Jenn-Air JCB2059G Bottom Freezer Refrigerator Logo
363 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
