Question about HP JetDirect 680n Print Server
How much is hp 680n wireless ethernet? and where can i get in china market? or can i get it from internet, from usa or other place? i need a website connected and the price.thanks
You can get them used and new on eBay. New is $195 + $10 shipping.
Posted on Feb 24, 2009
Can't connect to the internet with ethernet cable or wireless
ethernet jack may be fried.. Go to device manager and see if its disabled or non existant.
Jun 05, 2014 | HP Pavilion m7480n (882780389410) PC...
I have a HP pavilion m8020n with Vista OS. I have internet for a while now and suddenly internet just went out. i talked to my internet carrier and we troubleshoot the connections. they said it might be...
2008 PC, shows it has modem too, a dial up. so 3 ways internet.
\there are 2 ways on to the internet (Ethernet and wifi)
aka, wired and wireless, respectively.
sure wifi router works,too, and is more difficult to setup. (im not going there)
try a new cable
try another router port yet, try cycling power only to the router?
sounds like your vista drivers are messed up ,
if another PC works , with ETHERNET cable to router there.then the router is working, test 1, passes.
that means this PC is failing
the PC has a control panel and device manager
see that and the network part? (not wifi , the wired network chip)]
vista 32b or vista 64bit?
your PC came with intel old
  • Interface: Integrated into motherboard
  • Technology: Intel 82562V
  • Data transfer speeds: up to 10/100Mb/s
  • Transmission standards:10-Base-T Ethernet
the driver is?
Intel 82562V
to make that chip work,
intel has it. 6 th down this list, Vista
https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller
load this driver. fixed. (from a working PC on the net)
then move it to dead pc and load it.
you are plugged in to X here. right.
or is there a card plugged in on the right, with RJ45 ethernet jack.
yes, you sure can add a new Ethernet card if the X jack blows out.
p5lple-fvyief5l4kybalhvncmspljg-3-0.jpg my DM ethernet port, im tying through it now...
mines a w10 gigalan port. so... is not intel like yours. ignore Realtek name pretend it says, Intel 82562V
May 23, 2017 | HP Pavilion m8020n PC Desktop
I cannot connnect wirelessly with my linksys e1000 router and was told by their experts that my hp pavilion entertainment pc needed an update for the driver of my wireless adapter. I did go to hp website...
Check the following steps to connect wireless linksys router :
First, you have to connect the router to the ADSL or the cable modem.
Your system has to be set in such a way that it will get its TCP/IP network settings from the router via DHCP.
Second, you need to configure the router to use your Internet service.
Connect the antennas to the Linksys wireless router. Connect an Ethernet cable to the Internet port at the back of the Linksys router and it will establish a connection between your modem and router.
Connect another Ethernet cable between the computer and the router. Then connect the router to an electrical outlet.
Dec 04, 2010 | HP Computers & Internet
Desktop wont connect to internet but laptop will
Is your cable modem also a wireless router?
From my search on it, it is not a wireless router.
This means you need to attach a hub or a wireless router to your cable modem so that more than one computer can connect to the internet simultaneously.
Go out and buy a wireless router. Connect the wireless router to your cable modem.
Connect your desktop to the wireless router with an ethernet cable.
Then you should have internet on your desktop.
Let me know if this helps. Give me a good rating and vote for me please.
Mar 24, 2010 | HP Compaq Presario SR2011WM PC Desktop
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
I cannot get my wireless internet to work. I need
Either call your ISP or HP phone support as the drivers for wireless hardware have to be reinstalled and then need to configure the wireless connection again. Make sure you have a ethernet cable with you as it will be required to configure the wireless connection
Oct 11, 2009 | HP Pavilion dv1000 Notebook
Solution for ''My hp pavilion notebook will not connect to the internet using a high speed cable modem''
Can you clarify?
Are you trying to connect wirelessly? or directly with an ethernet cable?
For either case, visit the hp support site:
http://welcome.hp.com/country/ca/en/welcome.html#Support
and then select your model (located in bottom of laptop), then download the wireless LAN broadcom (for wireless) and nvidia ethernet cable driver (or something similar to this.)
Hope this helps, and please rate!
Jun 18, 2009 | HP Computers & Internet
I am unable to connect to internet explorer on my hp laptop
You either need drivers for your Ethernet and/or wireless card.
Or you just didn’t plug in the Ethernet cable or you are not connected to any wireless access points.
Jan 08, 2009 | Compaq Presario Notebook
CAN I USE AN ACTIONTEC G704WG IN THE FOLLOWING CONFIGURATION: 1. CONNECT THE G704WG TO MY PC, ETHERNET TO ETHERNET 2. COMMUNICATE WITH MY NEARBY HP LAPTOP WIERELESSLY, BACK AND FORTH. THANKS, WAYNE...
yes that is possible connect your PC to the actiontec using the lan cable. set your wireless network, then have you other hp join the network.
you can share folders, and printers, and also have your HP connect to the internet through that actiontec.
Jan 06, 2009 | Actiontec GT704WG Wireless Router...
How to get hp wireless assistance
If you need to find the Wireless Utility to scan for available networks, it should be in Start > Programs under HP Wireless
If you need to turn your wireless adapter on:
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | HP Computers & Internet
Open Questions:
See all HP JetDirect 680n Print Server Questions
HP JetDirect 680n Print Server Logo
1,121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
