Question about Dell Dimension 4600 PC Desktop
Speakers dont work
The speakers are hooked up properly but there is no sound. The volume control will not come up it says there is no active mixter device avaliable.
    Champion:
  • 209 Answers
You need to install the driver coming from your motherboard cd. if you have the installed souind card you need to install the driver for this in order to activate the sound
Posted on Jan 24, 2008
Speakers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers
make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps
Jun 14, 2012 | Computers & Internet
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
My speakers are plugged in and they don't work. if i hook them up to my son's mp3 player they do, but as soon as i hook them up to the computer they dont
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 20, 2011 | Labtec AMX 2000 Computer Speakers
No sound
have you got the right sound card software?? have you checked if you speakers are hooked up correctly and that all of the cables are intact?
Jul 12, 2009 | Computers & Internet
I dont know how to get my speakers working
The audio cable on the speakers should go into the green audio port on the back or your PC. Once that is plugged in, if you still don't have sound go into your sounds and audio devices in the control panel and make sure the volume is not off or muted.
Mar 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
No Sound
if your sound card is properly installed, click on start,programs,accesories, entertainment,volume control.
Adjust the volume control settings.
Jul 14, 2008 | Audio Players & Recorders
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
Dell A215 Speakers
I think you probably have an issue with your sound card and/or its drivers. What model PC and operating system do you have?
Jul 15, 2007 | Dell A215 Computer Speakers
Dell Dimension 4600 PC Desktop Logo
90 people viewed this question
Alun Cox
