Question about Motorola Mobility A630
Cell phone problem as below
I have a Motorola A630 phone. The outer keypad buttons function erroneously . I can press only the 1 and the 9 button so as to dial the emergency no but cannot dial anything else. The inner keypad functions correctly and is the only way I can operate the phone. The outer keypad sometimes starts functioning randomly (more so near a high power magnet) but stops working again in a minute or so. please provide me any suggestions to solve this problem.
    Brigadier General:
  • 7,752 Answers
The cable may need to be replaced or have the keyboard service.
Posted on Mar 25, 2008
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
My phones keypad"s 9 no
The problem is that the rubber below the number keypad has actually gotten weak or faded away if i must say, just have it exchanged_by that i mean they will add some more rubber so that when you press the button it simply functions, it is not a big problem as such, find a phone technician and they will correct the rubber plate below your keypads okay.
Dec 11, 2010 | Motorola Mobility SLVR L7 Cellular Phone
What can i do with a motorola v3 phone that when you press any button it just comes up with the volume control on the screen and the phone won't work can this be fixed?
This can be fixed. The problem you are facing right now is with in the internal circuit which is placed below your keypad of your mobile. The circuit is sometime damaged because of some lubrication enters into it or because of excessive power applied while pressing the keypads. You just need to show your mobile at a repair store and he will fix your circuit. Once the circuit is repaired your mobile will function properly as it was working before.
May 29, 2010 | Motorola Mobility RAZR V3
Keypad,on off lcd
For the samsung you are to remove the casing and below the casing where we have those button touching the board with a white nylon on it try oning the phone without the casing and be pressing your keypad on the nylon with a pencil or pen to get where the fault is from . if is not pressing down at all then the nylon must be change because is the one the keypad will press and the nylon will be sitted down and up.
check that out.
kindly rate this solution..
May 07, 2010 | Samsung SGH-E251 Mobile Phone - Black
Dont know how to change txt alerts what section do i find alternative txt tones on motorola v3
1. press the middle button "-" at the top of the v3 keypad.
2 go to settings, and press on the button with a screwdriver and spanner
3. go to ring styles, press on the line below style.
4.Go to text msgs and press change to alter
Oct 23, 2009 | Motorola Mobility RAZR V3x Cellular Phone
A630 my front keypad only the 9 an 1 work can this be fixed an how any help would be great...
had the same problem! it is just a magnet that goes on the lid of the phone, just put that magnet on place again and the problem should be solved!
Jun 11, 2009 | Motorola Mobility A630
Buttons do not work
Sir/ madam,
the keypad is disabled, to solve it follow the instructions below
  1. open the phone, use the net to look for the guide in dismatling your phone
  2. after step 1, clean the connectors and board carefully
  3. check for cracks or missing components
  4. realign the keypad
  5. tryswitching it on and test the keypads
  6. if its done, assemble the phone
tnx
Feb 04, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
Jan 24, 2008 | Motorola Mobility A630
Motorola Mobility A630 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
