Question about Pioneer AVIC-N2 Car DVD Player
Reading error/Mechanism error
My Avic N2 will not read or eject any type of disc. As a matter of fact the the disc drive won't even turn. But when I push the eject button randomly it would randomly say Reading format, Reading error or Mechanism error. I know it is not a faulty disc drive because when I took it out and tested in my N1 unit,  the drive function perfectly. Any help would be greatly appreciated.
  • 5 more comments
  • hogan doan
    hogan doan Jan 24, 2008
    Yes, I did. I have tried almost everything that I can think of and nothing works. I consider myself of having advance knowledge about these Avic N-series as far as mechanical wise. But I have no solution for this problem.
  • hogan doan
    I can fix it fairly easy if it only say Reading error(laser alignment), Mechanism error(spring, gear or motor...) or Reading format = Unplayable disc(dirty laser). But this one randomly say all three when I push the eject button. Please remember the disc drive function perfect when I test it in a different unit and I even put a perfect different drive in the same would happen. It won't mess up the drive, it just won't turn and randomly display the described phrase. Thank you.
  • hogan doan
    Thank you for trying but my problem is alot deeper than just resetting, my loading/ejecting mechanism and disc drive are completly dead but when I tested in another unit everything work fine. I think that it doesn't get any power from the board, may be one of the IC that regulate the current to the whole drive might be toasted but visually everything look OK. Any other suggestion that you have I would surely try. Thank you.
  • hogan doan
    First I like to thank you for your expertise. I did what you suggested but I could not get pass the insert disc step because my load/eject mechanism and disc drive are completly non-functional. I think one of the chip that regulate the current to the whole disc drive unit had failed. But I can't see any sign of a short circuited one. Do you know which one regulate the drive may be I can test see if it works? Any suggestion will never be taken lightly by me. Thank you.
  • hogan doan
    By the way I did replaced the ribbon cable, that is the first thing I did. Thanks.
  • hogan doan
    Which one? I counted more than 10 surface mounted tiny fuses on both side of the circuit board. Some as small as a pin tip. I am dead serious about the size. Sorry guys if I sound imposible, I have more time than money and I think that I am so close to get this drive going. I just need a little more help. Thanks for all your efforts.
  • hogan doan
    Is everybody giving up on me already? I talked to the guy who run the the auction on Ebay that would fix all Avic N-series problem and he confirmed that the IC chip which regulate the disc drive is commonly the culprit for my problem. But he doesn't tell me which one it is. Ofcourse he is not going to give out his bread and butter. Does anyone know which IC chip he is talking about and where is it located on the board? If you ever fixed a similar problem on a different brand or unit and remember the diagram please drop me a line and I think I could figure out the rest. Thank you in advance.
    Champion:
  • 207 Answers
Have you tried to reconfigure your drive? try to reconnect your buswire on it then restart your computer to detect the device properly..
if still doesn't work, let me know here.
Posted on Jan 25, 2008
  • Gil gil
    Gil gil Jan 25, 2008
    i believe there is an issue with regards of chipsets that are found on your motherboard. Because, once this tend to be damaged..it will obtain an error not only your CD-ROM but to other devices as well.. The best solution you can get is its you have to refer your motherboard to the manufacturer OR replace it with a new one since the circuitry of motherboard are interdependent with each other. If one circuit will fail to load or damaged, it will affect the whole status of your computer.
    Scholar:
  • 143 Answers
Have you checked the internal fuse, intergrated on the circuit board with in the unit.
Posted on Jan 24, 2008
  • Aaron Prentice
    Aaron Prentice Jan 24, 2008
    i dont know which one but im sure i have had a simluar issue, continuity test them all.
    Novelist:
  • 167 Answers
It may be worth it to get your Navigation Flex-Cable replaced for free as Pioneer just released a statement saying that, "After a number of power cycles, the cable has been observed to fail and cause the unit to malfunction (symptoms may include, but are not limited to, the flip-screen becoming blank)"... who knows maybe the cable is causing other issues
Link to FAQ on Nav Flex-Cable free replacement
  • Steve Stonebraker
    Steve Stonebraker Jan 24, 2008
    How did you try to reset it?
    There are a couple of different methnods:
    Resetting the microprocessor
    • Pressing the RESET button deletes the contents of the product’s memory.
    Pressing RESET button lets you reset the micro-processor to its initial settings without changin the condition memory.
    The microprocessor must be reset under the following conditions:
    • Prior to using this unit for the first time after
    installation.
    • If the unit fails to operate properly.
    • If there appear to be problems with the opera-
    tion of the system.
    • When changing the combination of the equip-
    ment.
    • When adding/removing additional products
    that attach to the unit.
    • When the display and the Hide-away units are
    re-connected.
    FIRST METHOD
    1. Turn the ignition switch OFF.
    2. Press RESET button with a pen tip or
    other pointed instrument.
    SECOND METHOD
    After completing connections or when you
    want to erase all memorized settings or return
    the unit to its initial (factory) settings except
    for some navigation items, switch your engine
    ON or set the ignition switch to ACC ON
    before pressing RESET button.
    President:
  • 1,944 Answers
Did you try reseting your unit?
  • Damen Wong
    Damen Wong Jan 24, 2008
    Did you try this reset process?
    REMOVE DISK
    HOLD RESET AND EJECT
    RELEASE RESET BUT HOLD EJECT
    SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
    THEN WITH JOY PAD PRESS …
    UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
    PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
    TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
    SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
    FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
    PRESS 1 SYSTEM PROGRAM (OK)
    SELECT 2 DVD/CD ROM (OK)
    SELECT LANGUAGE… (ENGLISH)
    PRESS (VIEW –POS) BUTTON
    SHOULD SEE SYSTEM PROGRAM GOING UP IN %
    WHEN FINISHED PRESS (BACK)
    FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
    NUMBER 3 APPLICATION PROGRAM (OK)
    SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
    SHOULD SEE SYSTEM GOING UP IN %
    TEST MODE PAGE 1
    SELECT 6 - CLEAR BACK UP MEMORY (OK)
    SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
    PRESS RESET ON FRONT OF UNIT
    START SAT NAV AGAIN
    ASKES FOR LANGUAGE PRESS NO (READ TEXT)
    SYSTEM STARTS
    BUTTONS
    OK = JOYPAD INWARD
    BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
    BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
    http://www.avic411.com/forum/viewtopic.p...
I changed the Navigation disc to west side and can't get it to accept the east side navigation Disc? Is it possible? How?
eject the disc and reset the radio. then try to insert the east coast disc again. should work again after reset
Feb 06, 2010 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
AVIC N2 WONT READ MY NAV DISC,WHEN I PUSH MY MENU BUTTON IT SAYS INSERT APPROPRIATE DISC, NOT SURE WHAT DISC IT WHANTS
The nav discs come in a set of two. Disc 1 and Disc 2. Insert disc 1 first, if unit does not respond or read nav disc, then you may have a bad copy of the nav disc or incorrect copy.
Jun 09, 2009 | Pioneer AVIC-N2 Car DVD Player
Setting the clock on a Pioneer AVIC-N2?
Here is a link to the manual and install guide. pioneer
Software go to ebay there is someone selling the East disc for 60 and the west disc for 60 . that is the cheapest i have found
Feb 20, 2009 | Pioneer AVIC-N2 Car DVD Player
Disc reading error
Hi, please browse through my solutions. You will find your answer there. Good luck.
Dec 03, 2008 | Pioneer AVIC-N2 Car DVD Player
Avic-n2 won't read the navigation disks...
If it play cd's but not not dvd's or navi disc then your laser is "tired" or out of alignment. If it does not play any type of disc then it needs a new laser pick unit. A capable tech should be able to re-align or replace the laser pick up unit for about $75 to $150. Contact me if you need it perfome. My number is 801-414-4566.
Jan 22, 2008 | Pioneer AVIC-N2 Car DVD Player
AVIC-N2 stopped working and wont stop flashing PLEASE HELP!
Sound like the ribbon cable because before breaking off completely the vibration of the engine can cause current to fade in and out(open and close circuit).
Nov 19, 2007 | Pioneer AVIC-N2 Car DVD Player
Avic N2
ok! that is sensitive to open it! FIRST clean the sensors under the cd plate! SECOND clean the laser lens. your cleaning method is to get a 100% cotton then clean all sensors and laser lens at clockwise motion!
Sep 30, 2007 | Pioneer AVIC-N2 Car DVD Player
Avic-N1 touch screen calibration...
1. Take disc out. 2. Press and hold eject and push the reset button. (don't release the eject button 'till screen closes and opens again. 3. Sceen will ask you to push reset.(don't) 4. With right knob... up,up,down,down,push 5. Perform steeps 1,2,3,and 4 only: The first outlines the screen The second has you push hash marks The third verifys The fourth Saves 6. Use "Band" buton for "back" 7. Press reset Be carefull......
Aug 07, 2007 | Pioneer AVIC-N1 Car DVD Player
I need ur help please
Can you make sure that your disc drive is turning when you load a disc. If it does I can help.
Mar 06, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
812 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
