Question about Sony Cyber-shot DSC-W55 Digital Camera
My Camera won't turn on and I have had the battery on the charger for a really long time and it usually takes about an hour. When I put the battery in the charger it just blinks red.
  • joelove Mar 09, 2008
    Hi I have an SVP DC-1059 each time i try to turn the camera on the busy light flashes for a couple second and off. Camera does not come on.
    Genius:
  • 2,985 Answers
More detail of the battery type please .
May be time for a new battery
Posted on Jan 24, 2008
6ya staff
SOURCE:
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
When turn on or power is push to on there is a message turn off and turn on again
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest samsung service centre...
thank you...take care
Oct 08, 2010 | Samsung Cameras
My battery died and i lost my charger so i bought a universal charger and it says the battery is fully charged, but when i put it in my camera wont turn on at all, a little red light flashes when i hit the...
dear sir,
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest olympus service centre and it is going to be done free of cost,as your camera is under warranty .......
thank you.....take care................
Oct 08, 2010 | Olympus Camedia C-350 Digital Camera
Screen doesnt work for some reason no damage has ever occurred
dear sir,
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest mustek service centre.
Oct 08, 2010 | Mustek DV5300SE DIGICAM Digital Camera
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Charging
    I do not know this particular camera but it is not usual to take a battery charge from the computer. Charger plug in the the household supply. Is this one different? There is usually a more comprehensive manual in PDF on the disk- have you checked that out. Finally get on to customer support, if you feel you are getting nowhere. I would like to know more about the battery charger.
    Jul 10, 2007 | Samsung NV3 Digital Camera
    After switching on - the lens extends and retracts repeatedly
    I had the same issue and thought me Ebay camera was trash. I put the batteries back on the charger over night and it worked properly in the morning. Looked to be a low power issue, but my lens did look like it was all cocked, grinding and stalling. perhaps the camera reset itself with no batteries in it for a few hours> I was very relieved.
    Jun 13, 2006 | Olympus Camedia C-5050 Zoom Digital Camera
    Sony Cyber-shot  DSC-W55 Digital Camera Logo
    Top Sony Cameras Experts
    james laughton
    james laughton
    JonSnell Electronic
    JonSnell Electronic
    john cordey
    john cordey
    Are you a Sony Camera Expert? Answer questions, earn points and help others
