Sony Playstation 3 (PS3) Console Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PS3 hdmi only working on some displays
I have a first generation PS3, bought in japan. It is the model with full PS2 hardware inside.
It works flawlesly using an HDMI-DVI connector (never any issue encountered on half a dozen displays).
It works as flawlesly whatever the display using the component cable (YPbCr) even at 1080p.
HDMI-HDMI connector is much more problematic.
It does not work on my Sony Bravia (52w4000), does not work on a LG, but it does work on my parents' Samsung panel (what i mean is that the TVs receive no signal at all from the PS3, neither data audio or video), all the sets are certified 1080p24,50 and 60.
I tried every combination possible, even unplugging for a long time the TV panels and PS3 to force the handshake, switching on and off with different order (first PS3 then TV on HDMI input, first PS3 then TV not on HDMI input and switch to HDMI input, first TV not on HDMI input then PS3 then switch to HDMI input, first TV on HDMI then PS3), tried of course all the HDMI inputs on every set.
I of course know of the long power on press to force the PS3 display reset, that when it is done only with the HDMI cable, it enables HDMI display with simplified hand shake, but nothing helps for pure HDMI-HDMI connection. I tried as well with both component and hdmi and trying to change display mode on the fly, but not working. Tried 5 different cables, from low end to very expensive without success.
It works on some sets and not on others whatever i try.
All the other HDMI devices (bluray player, internet TV box, digital movie player) work on all sets at 1080p (or 1080i for the internet tv box).
It is puzzling.
I keep my console up to date in firmware in hope the problem gets solved, but so far no progress.
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 99 Answers
  • Posted on Dec 21, 2009
Anonymous
Expert
Level 2:
Filmmaker:
Answers
99
Questions
0
Helped
36455
Points
282
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
How do I get my PS3 to work over hdmi?
Try swapping out HDMI cable. The version of cable. (1.2, 1.4 etc ) might be too old/faulty for PS3.
If your Tv is HD ready and not Full HD lower the video quality in the PS3 settings
tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
I live in South Africa and bought a PS3 Baseball game. It works in my PS2 but not in the PS3, because of the zone code. What is the correct zone code
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
I thought playstations are all formated to play any made of equal or lesser p.s. value such as p.s.3. should play p.s.2. games
I believe you're asking about backwards compatibility. While I agree a PS3 should be able to play PS2 games, it's sadly not always the case. While they all can play PS1 games, not every PS3 can play PS2 games. PS2 compatibility depends on the model.
Backwards compatibility with PS2 games has slowly been phased out. The original PS3's had hardware emulation (quite literally there is a PS2 inside of your PS3). The later revisions had software emulation only (PS3 processor pretends to be the PS2 processor), and then none at all. No slim PS3 has backwards compatibility.
Hardware emulation:
20 GB PS3 Fat/Original - Model CECHB01
60 GB PS3 Fat/Original - Model CECHA01
Software emulation:
80 GB PS3 Fat/Original - Model CECHE01
In my personal experience, there's no real difference between software and hardware emulation in terms of actual game play. Software emulation has a few hang-ups on some older games, but overall it works pretty well. And it's infinitely better than not having any ability to play PS2 games at all.
Links!
Wikipedia
Hardcoreware.net - Comparison Table
Sony - check compatibility of games with PS3
Hope that helps!
5helpful
2answers
Can you play PS2 games on a PS3?
If you bought the original PS3 when it first came out and purchased the expensive one with the larger hard drive, it will be able to play *some* PS2 games. If you bought the cheaper one with the smaller hard drive or purchased your PS3 once the prices started dropping, it will have no capabilities of playing PS2 games, as Sony has decided to not continue making the system semi-backwards-compatible.
2answers
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
No color
Sounds like you are having a issue with color format or a bad connection cable... In the US we use the NTSC color format, Japan uses NTSC-J, and Europe uses PAL. This matters quite a bit; if you have some Special Edition PS3 that they only sell in Japan and have it plugged into your Flatscreen TV in the UK no dice. Make sure you do not have conflicting regions for your hardware. Moreover, make sure the pixel resolution is not out of bounds for your TV's range. The PS3 has different connection cables for every kind of connection; RCA, HD, HDMI. I recommend using HDMI if your TV supports it.
No sound or display
go back to your friend or another with a hdmi tv then connect the ps3... when connected go into the menu for display and switch output from hdmi to scart it should then work on your tv
2answers
Playstations3
Unfortunatly not, only the PS3 60GB verson can do that.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
