Question about Gateway MX6124 Notebook
I have done some tests and think that my internal hard drive is not working (SATA)
If I purchase a new one, does it have to be the exact same thing? Can I purchase a 120 gb instead? Also, whichever I purchase, will I still have to reload xp? And do you have any other suggestions for acquiring an xp disc if I have to do that other than through Gateway or Microsoft? I would really really appreciate an answer. Thanks.
  • 1 more comment
  • Anonymous Jan 25, 2008
    I went to start my computer and I got the error "media test failure check cable" "No OS found". I went through the steps in the bios settings to reset it, no luck. I took the drive out and reinserted and went through it all over again, still no OS found. I am thinking, my files are gone. I can only get to the black screen with the error message or to the bios settings.
    um...how do i do that :)
  • 594 Answers
I cant read your original question, but I believe you say your hard drive is failing? You need to get a second one (any size with XP) and a USB enclosure to transfer the files. You can try it over a WAN/LAN but that may be a little time consuming. WinXP has this feature bulit in and most hard drives come with a migration tool that assists in transferring OS and files and making it the primary boot drive. Operate and swap drives after migration is complete. Be careful with a gateway or Dell PC as it has a hidden partition that may not transfer if not told to do so.
Posted on Jan 24, 2008
  • Steven Wander
    Steven Wander Jan 25, 2008
    You can also try removing one of the memory modules, as bad memory is a major cause of "no OS" or even "could not find pci.sys" problems, both cause XP to stop booting.
6ya staff
SOURCE:
I wish to Upgrade My HP Pavilion ZD8230US 100GB ATA HDD to one that is faster and has more Maybe as high as 500GB. SATA type drive would be great to have but unsure if I can install SATA Drive in this...
yes you can upgrade your hard drive but still on ATA,if you upgrade in SATA you need some converter from ATA to SATA .and since it's a laptop i think its hard to do that thing.
Sep 13, 2011 | Computers & Internet
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
Really is not a problem, my question is if can I add a new internal hard drive and which is the right one, i could suggest for the bigger available for this machine, thanks I wait for you sooner...
yesyou can,, you need a sata hard drive, any size will do. just purchase the sata cable, sata power adapter for the atx power supply and a splitter. put in the drive, connect the splitter to the power supply, and connect them to the hard drives and pulg the sata cable to the board.. thats it your done..
May 07, 2011 | HP Compaq Presario PC Desktop
My hard drive stopped showing up in windows and bios. Then it started to work again but only shows up as a 128 gigabyte drive. This is the second brand new Western Digital (WD5000AAKS) 500 GB SATA Hard...
that is a sign that this hard drive is also failing.
please contact WD to RMA this hard drive back.
you can submit a complaint to them saying it is the 2nd drive that you receive that is going bad from them.
they may send you a different model or similar model.
Mar 28, 2011 | Western Digital (WD5000AAKS) 500 GB SATA...
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
Board burned want to recover data
I have done so by getting another working drive exactly the same & replacing the motherboard of the bad drive, this works as long as the internals aren't fried.
Jan 31, 2010 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | ASUS K8S-MX Motherboard
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Putting together and external HD
    You purchased a SATA hard drive. Your enclosure is probably meant for an IDE hard drive. If you can, return the SATA hard drive and exchange it for an IDE hard drive.
    Jan 14, 2008 | Computers & Internet
    External/Internal Hard Drive
    Right click on My computer,then manage,disk management, if popup occur,click yes to all and finish,then right click on new drive,create new partition,click yes to all, wait for format.....done.If you don't want to format or already formatted then right click on drive, change drive letter and paths and assign new drive letter away from c.d or e...make it x...problem should be solved JJ
    Sep 15, 2007 | Compaq Armada E500 Notebook
    Gateway MX6124 Notebook Logo
    Top Gateway Computers & Internet Experts
    Ekse
    Prashant M
    Prashant M
    Thomas F. Schneider
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
