I have connected my Velodyne CT80 to the "mono out" on the back of my dolby 5.1 receiver. The subwoofer has worked for a few years but now is not working. The power on the subwoofer still comes on, but no sound will come out. Receiver settings are for a subwoofer to be connected. I get a "humming noise when the jack is partially conneceted but goes away when fully connected. What can be the problem?
Thanks,
Ken
The humming noise is caused by stray electro-magnetic waves that surround the wiring in your house. When you have the cable partially connected, the ground of the cable is not making a connection with the ground on the sub. The inside conductor in the cable is exposed to the stray electro-magnetic field, and transfers this to the subs amplifier.
The fact that the sub makes noise when you do this, indicates it is probably functional. Your problem is more likely to be in the cable, or the pre-amp supplying the signal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
One of two things may be going on.
The amp has a fuse mounted on the PC board. The fuse may be blown.
The speaker may be bad. that may have blown the fuse.
You can test the speaker with a "D" battery.
Take the amp section out of the back, disconnect the speaker leads.
Touch the speaker leads to the poles of the battery. it should make a little thump and the cone should move freely.
Contact Velodyne for service.
