If you engage the 4WD with a switch instead of manually, there is a motor in or on the transfer case. Because of the location, these can go bad.
u need to check all your switches and actuators there are actuators under vehicle that clog up with dirt.also try putting vehicle in neutral before engaging 4x4.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
If I recall correctly, there is a small vacuum line that connects to the transfer case that sometimes clogs or pops off, preventing the 4wd from engaging.......
On
these issue, there are few solved help links for troubleshooting the
issue easily.-------
Click
the link below: ---
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction
control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light
flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These
details will help.
Thanks.
