Washing machine My washingmachine is about 4 yrs old, when I wash I notice a small amount of water under the washer. What can it be?
  • 244 Answers
Open the door pull back the flap of the door seal and check the door seal for holes this is usual problem also check the pipes which connect to the washer check if there is a small leak from them after time this will build up the water thse are the most common problems let me know how it goes
Posted on Jan 24, 2008
  • 67 Answers
Could be anything from a faulty connection to a sick pump. Could even be splashover, the only way to find out is to remove the cover (if possible) and look hard. It may be obvious. Good luck.
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
Jun 29, 2005
More results from
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
An excessive amount of water is coming out under my washing machine at the end of the wash cycle when draining. My email is the machine is only 2 yrs old.
the drain pump is probably cracked!! or the drain hose is lose or broken to the pump from the bottom of the pump! you will need to put the machine on it's side to check the pump and hose from the bottom of the machine where it hooks to the motor shaft
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Water Building up Inside Front Load Washer when not in use
Okay, it is normal to hear water sloshing around inside the wash tub when the washer is not in use. A small amount of residual water remains in the wash tub under the wash basket (stainless steel tub), and resides in the drain line and drain pump. That's why it is important to keep the door slightly open when not in use to allow the drum to air out. The water will not evaporate, but it will help reduce the build up of odors, mold and mildew.
Now...if your washer is slowly accumulating water in the wash basket area over time, your water inlet valve is probably starting to fail. The leak can be very subtle and you may not notice it. The water only comes from one source - the fill valve via the dispenser. If you wish to replace it, the part is available at Just type in your model number and the part you need can be found under the "Dispenser" heading as item number 1. The replacement is very simple if you follow these steps:
1. UNPLUG the washer and turn off water supply.
2. Remove both fill hoses.
3. Remove the top panel of the washer by removing the screws that hold the panel in place in the rear of the washer.
4. Slide the top panel back, then it lifts off.
5. The water inlet valve is located in the left rear of the washer as facing from the front.
6. Remove the rubber hose leading from the valve and the electrical connections.
7. Remove the mounting screws holding the inlet valve in place.
8. Re-install new valve using these steps inthe reverse order given.
I hope you find this information helpful. If you have further questions, please post back and let me know.
Jun 06, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag SAV205DAWN, loud and leaking!!
the main seal is leaking and water has goy into the bearings,needs to be stripped and rebuilt
Nov 09, 2017 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
