Question about Acer AL1916W 19" LCD Monitor
Can't manually adjust color
All I seem to be able to do with the 'eColor Management" is to move the arrow to light up one of the modes, then an auto adjust box opens, and there is no, or very very little difference in the image onscreen.
While I was going through this process, a window that had brightness and color bars with an arrow on each (indicating that this was where you could make an adjustment) aapeared briefly, then disappeared.
The manual tells me nothing..all that is offered is autoadjust.
What am I missing?
Thanks, Jane
  • rdharma Jan 26, 2008
    Thanks for the response, but I think we have a dud. When you change the settings, they won't stay..they just go back to where they were before.
    Plus, the options for color changes just aren't enough. My husband and I are both artists and the colors on our websites are super important.
    Bottom line is I think we need to spend more $. Our old giant monitor was better.
  • rdharma Jan 29, 2008
    The screen is good now. I also had to realize that I have to be sitting directly in front of the screen..standing beside my husband and him adjusting it obviously (in hindsight) wasn't working...
    I liked our old screen better in that sense...more than one person could look at an image at the same time and see the same thing.
    I tried to click Fix-ya on the rating, but this window kept opening when I did and so I'm saying here I rated it.
    Thnaks, Jane
    Novelist:
    Scholar:
  • 108 Answers
I happen to have an Acer Monitor although a later model. It has 4 buttons....one of these is the auto adjust and one other is the window that has manual controls (so to speak). If you look at it carefully...(and it should stay on the screen for at least a minute - they believe you will do something in that timeframe)...you will find a set of icons at the top. These are suppose to be visually intuitive (and they are after you have used them once or twice)....anyway, if you really want to set your colors manually and or make other adjustments....alignment et al...you use the other buttons when the manual control screen is there. Experiment a bit and you will discover what does what. FYI...all "modern" monitors have this ability....the icons differ....but autoadjust does the best job in general....personal preferences and eyesight withstanding. Good luck....a small glass of wine sometimes helps the process and reduces the frustration level the first time around.
Posted on Jan 24, 2008
  • Stephen Jones Jan 27, 2008
    One last thought and I played with mine (the later model). It has a color palette that allows you to adjust red-green-yellow, It is an Acer AL2002. I did that for drill and then "set" it by pressing the left side manual button when done which is, on this monitor, also the button that puts up the small screen. I suspect you may have done this so my apologies...it was just a thought. FYI...my son is also an artist (studied with Od Nerdrum among others and graduated from Philadephia Acadamy of fine arts)...his website is SethCamm.com. What is on the site is not really representative of what he does (and likes to do) but starving artists who do house portraits at $4.00 an inch at least eat. Does have a couple of other pieces that are interesting (in addition to his "homeless project".) Hope all works out.
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
I have an ACER X203H and cannot adjust the contrast or the brightness. I can bring up the MENU, however I cannot adjust because when I HIT ENTER the menu disappears.
Press the Menu key on the Monitor to bring up the dialog box press Menu again because it defaults to the Brightness Icon. You will see the lower half of the dialog box change color. Use the left or right arrow to move off of Acer eColor Management to the User setting. Then press Menu again to edit contrast or brightness. User the left and right arrows on the Monitor to move to the desired adjustment, press Menu to allow adjust then arrow left for less or arrow right for more.
You really just keep moving between the Menu and arrow til you get it right.. I definitely needed to turn down the brightness on my monitor.
May 04, 2010 | Acer X203H bd Monitor
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
Seems like a convergence issue has begun
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 16, 2007 | Hitachi 51UWX20B 51" Rear Projection...
Getting accurate color
1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Acer AL1916W 19" LCD Monitor Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
