Question about Microsoft Xbox 360 Console
4th controller slot wont work
I have an xbox 360 and all my controllers are wireless all of the conrtollers work but none of the controllers will go into the 4th slot i kept changing the controllers around but none of them worked
    Problem Solver:
  • 17 Answers
It sounds to me like there may some sort of frequency conflict. I would call 800-4my-xbox and report the problem to them. If there is some sort of conflict, your box may still be under warranty (MS extended warranty on all consoles). After all, there's no repair like a free repair!
Posted on Jan 25, 2008
I have 3 flashing red lights on my xbox360 what do i do
Microsoft Xbox 360 Wireless Controller When I
If the battery has run flat you may need to pair the controller to the Xbox, Switch on your Xbox and press the small button to the right of the memory card slots, the four green lights will start to flash. Now press the small button that is next to the socket on the front of the controller.
Dec 19, 2010 | Microsoft Xbox 360 Wireless Controller
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 will not search for wireless controllers when search button is pressed
For pairing the Xbox 360 controller make sure you hit the pairing button on the wireless controller and Xbox 360 unit together, there's a little circular button under the memory card 2 slot, press it (while xbox is on)
now press the one on the controller (next to lb) and it should connect.
here's a diagram representation of pairing process for further help
Hope this helps, Please do take time to rate my solution
Wishing you Happy Holidays and Happy Gaming
Regards
KreativeGeek
http://gamingbox.wordpress.com
http://www.kreativegeek.com
Dec 27, 2009 | Microsoft Xbox 360 Wireless Controller
I hold the center button down, it starts blinking but never goes to 1st, 2nd, 3rd, or 4th player.
1.press the centre button 2.press the small button on top of the controller3.press the same button but now on the console
4.wait
if that dont work then idk
Nov 01, 2009 | Microsoft Xbox 360 Controller
Wireless Control
if this for xbox 360 elite or just regular, your wireless controller need a good battery, Once you replace the battery. Connect the wireless controller on your xbox closely and go the sub menu of xbox 360 to check the configuration for wireless.
Jul 23, 2009 | Microsoft Xbox 360 Controller
My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
May 30, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Feb 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller wont work
Did you try syncing it into the 360? If you did and it didn't work get a new controller.
Dec 27, 2008 | Microsoft MS Xbox 360 Common Controller...
Xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Nov 13, 2008 | Microsoft Xbox 360 Wireless Controller
Wireless controller position
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
http://www.xbox.com/en-US/support/systemuse/xbox360/resources/supportfaq.htm
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Sep 01, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
