Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Can't connect 2 laptops at same time through wireless (SMC2804WBRP-G ) Hi I can connect either one of the laptops as long as the other one is not connected, but whenever I try to connect the other one, I can't get a connection (seems to stuck at " Acquiring IP address" stage). I've tried forcing different IP addresses in each laptop,, but still can only get one at a time. One Laptop is a Compaq Armada M700 with and smc Wireless G card, and the other one is an IBM R40 with a D-LINK Wireless G (DWA-642). Before I had a D-Link Air Wireless B (DWL-650) with same results. At another location, we could connect both laptop at the same time (different router, but don't remember which brand). Both Laptops are running WinXP SP2. Security settings is WPA-PSK TKIP. Any suggestion would be appreciated (I don't mind re-trying things I "Think" I did, if need be). Thanks
  • D_The_Cat Jan 30, 2008
    Thanks for answering.
    DHCP was enabled.
    Other suggestions?
I have had the identical issues with my same router. Could not overcome the issues in the last three years of operation before it finally died (wall wart packed it in and it took out the whole unit). Try another brand - not worth beating the issue to death like I did.
Posted on Feb 05, 2008
    Problem Solver:
  • 21 Answers
Make sure that the dhcp function of your router is enable
Posted on Jan 25, 2008
  • edhel joy callo Jan 30, 2008
    Have you updated the driver of the card of that laptop that can't connect? Is that wireless card compatible with WPA encryption? Or you might need to check the firmware of your router is its updated as well.
How do i find the wep key on my smc2804wbrp-g wireless router. I need to input it into a nintendo ds lite, that is not able to connect to it. I was going to manually enter all the numbers.
The WEP key is the key that you use to access the Internet through the router. If you use a laptop to get on the Internet, you are asked for a password before you can surf the Internet. That password you type in is the same you should type into your DS Lite.
If you don't know, then you can get a paper clip and push the reset button on the back of the router for 30 seconds and that will erase the password.
Apr 06, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
Wireless routher will not connect to my computer wirelessly. If plugged in with ethernet cord, internet works fine.
make sure that your computer's wireless adapter is turned on. usually laptop computer came with wireless switch on the side or infront of the laptop. you can also enable the wireles adapter of your laptop by pressing Fn key + F5 or F6 depends on the laptop brand. just look into the F keys with computer picture and signal in it.
Apr 04, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Can't connect my new Brother MFC490CW wireless printer. I do I proceed to activate my printer with this router (SMC2804WBRP-G)
ti is a wireless printer.
You will need to connect to the wireless network on the printer.
you will need to check the wireless settings of the router.
Click Here to know how to check the settings of the router.
Nov 01, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Help
wat is the make and model of the router?
try to upgrade the firmware on router to resolve wireless problems
Sep 06, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC2804WBRP-G vs Wii
do u mean wifi?
if so wat in specific do u want to configure wirelessly?
Jul 03, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
My laptop cannot locate my network
I can not open my labtop on my wireless, it ask me for my password, I give it and it tells me it is the wrong one. I have 2 computers on it with know problems..
Feb 25, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
Problems with SMC2804WBRP-G not detecting/connecting with Windows Vista
i have a similar problem with SMC7904WBRA2 Barricade router. I can only intermittently connect from my Vista Home Basic PC to the router. Most times I am unsuccessful.
Feb 19, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
One Notebook not connecting to the Base
It seems that you are not connected to the wireless connection ..i think the operating system in your laptop would be xp..to fix this problem
right click > wireless n/w connection > click view wirelss network connection > click change the order of the preffered network connections > select your wireless network name > from preffered wireless network and remove it..and then right click wireless network connection icon again and try connect to the network.. you will get connect.. and will get an ipaddress..
Nov 20, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Router
click start, control panel, internet options, connections tab, remove anything you see in the "dial up and vertual private network, click on LAN Settings, the only one that should be checked is "Automaticly detect settings, click ok and close all. open internet explorer if problem still there disable firewalls.
contact me if you still have issues.
Nov 04, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
113 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
