Question about Kenwood eXcelon KDC-X559 CD Player
Toc code keeps comeing up on my kenwood kdc x5589
I bought a pick up with the deck in it then the truck died so i pulled tyhe deck put it in my daughters car .i hooked it up correctly and now it works on the radio but put a cd in it it comes up "TOC ERROR"i looked in the owners manual and cant seem to find a solution. please help me 16 year old daughter is driveing me nuts!!
thanx
jim
  • 78 Answers
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Posted on Jan 25, 2008
Just bought vehicle, kenwood KDC 722 stereo wont work till enter 4 digit security code.... ANY suggestions??
You have to go to a Kenwood car audio dealer in your area. They will pull the unit and get the serial # off the deck, call Kenwood and get you the code. If you pull it yourself you can save a little $... If you don't have the manual, go to www.kenwoodusa.com type in your model # under support and you can download install manual as well as user manual for free. Depending on the vehicle, it could be very quick or take an hour or so to pull the unit, it all depends on the mount. Hope this helps
Dec 12, 2009 | Kenwood KDC-MP238 CD Player
Security code lost
if you did not add a code to unit just ignore that code say and push source and unit should come on all kenwood deck say that'
Oct 09, 2009 | Kenwood KDC-422 CD Player
Need to reset the code on my Kenwood deck.
you should try the defaults 0000,0123,1234. in most cases unless you or the original owner put in the security code. Worse case it will just keep turning off till you get it right.
Apr 13, 2009 | Kenwood KDC-MP4032 CD Player
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
Toc error
i have had the same deck for four years and installed and removed from 4 different vehicles. the deck has been through some stuff lets put it that way. mine does the same thing as yours, i have found that you just keep ejecting the disk untill it reads. usually only takes a couple times and then mine works just fine.
May 26, 2008 | Kenwood KDC-MP828 CD Player
TOC ERR
this is caused from the pickup needing to be cleaned(lazer) remove deck remove small phillips screw on top plate use a damp q-tip (alcohal) gently rub the lazer top with the q-tip allow to dry aprox 10min reasemble and enjoy. Also make sure u don't need a security code for your radio before u unhook the power plug!!!!
May 16, 2008 | Kenwood KDC-MP228 CD Player
E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Feb 25, 2008 | Kenwood KDC-MP205 CD Player
KDC-MP228 cd no play w/ codes
Gave up on it and bought a pioneer. Kenwood said to take it in to a service center. The service center would have cost me more than the crappy stereo.
Jan 11, 2007 | Kenwood KDC-MP228 CD Player
Kenwood eXcelon KDC-X559 CD Player Logo
218 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
