Question about Creative Labs Zen MicroPhoto MP3 Player
Still wont work
It says its charging but it dont turn on unless its hooked to a computer then it goes to a recovery mode and when i click something it freezes on that
    President:
  • 4,402 Answers
Try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update
Posted on Jan 24, 2008
6ya staff
SOURCE:
My iphone 3g wont turn back on. the facebook app was acting up so i did a hard reset. once i turned the phone back on facebook was still acting up so i did the hard reset again within 5 mins. when i tried...
You could try putting the phone into recovery mode, then resetting the firmware through iTunes. To enter recovery mode you must: 1) Open iTunes and connect your iPhone 2) Press and hold the home button and the sleep button at the same time. 3) After 10 seconds, release the sleep button but continue holding the home button After following these steps, your iPhone should now be in recovery mode and ready to be restored using iTunes. Good luck!
Mar 12, 2011 | Apple iPhone 3G
When turning computer on boot start and freeze when screen show F2 F12 . Nothing else work no matter what key I press. It wont even turn off unless we disconnect power supply and remove the battery.
It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to
the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now,
restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are
prompted), it will restart the computer. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e
Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 27, 2010 | Acer Aspire One PC Notebook
When turning the computer on it wont load and restarts
charge. Let us try the basic troubleshooting. Turn Off the Netbook, remove
all the devices attached to the computer, the power cable and battrey, now
uplugged) it will drain out all the static charge. Now, restart the computer
process as you will loose all the datas on the computer. To do so, Turn Off
"AltGr" (it is on the right side of the spacebar key) & keep on tapping "F10"
key, i.e AltGR+f10, it will open the recovery console, select full factory
on the computer.
May 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
My iphone wont turn on
Have you tried doing a hard reset, Holding down both the home button on the bottom face of the phone and the on/off switch on the top left of the phone. Holding both those buttons down for about ten seconds will cause the iphone to restart and give you an apple symbol. when you get the apple symbol you can release those buttons.
Sep 27, 2009 | Apple iPhone Smartphone
Psp wont turn on green light goes on then turns off
http://forums.afterdawn.com/thread_view.cfm/688507 go to the fifith comment or so and do as told
First of all try hold the right trigger if a recovery mode pops up go to usb mode and hit X. hook it up to ur computer and then run psp deluxe and tell it what drive ur psp is and then do what they tell you to do and set dcmenu as left trigger and start it and then trun off turn back while u hold left trigger! if a menu comes up with 4.01 m33 do that!\\
HEY MAKE SURE ITS PLUG TO A CHARGE AT ALL TIMEs
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Turn on
dear watevr,
During recovery mode, the computer could've changed to default settings that may interfere with the mp3 player's ability to charge.  Try reinstalling the cd that came with the sandisk.
Feb 12, 2008 | SanDisk Sansa e200 MP3 Player
Wont turn on
If you use the my computer setting to format your player, you need to update the firmware on the device..to do so...go to
http://sandisk.com/Retail/Default.aspx?CatID=1376
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Recovery mode wont work
you should try to connect it to another computer sometimes the computer dont seem to connect to each other so try to connect it to another computer. hope it helps
Sep 06, 2007 | SanDisk Sansa e260 MP3 Player
Randomly Went to Recovery Mode
The hard drive is bad and you will need to get it replaced. There is a repair service box on this page if you scroll down; just enter your zip code to find a repair service near you.
Aug 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
51 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
