Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi 46F500 46 in. is still bad
After replaced 2 pcs STK394-160E, it still looks 3D. then I found RK42 bunt out, I replaced with 3.3 ohm, it looks better, but green lines are still off a little.
also I found RK47 has 1 ohm on board, (RK47 is good out side the board) and same value RK55 and RK63 showing 147 ohm on board..any ideas?
thank for help or please email me a schematic to rcml2001@yahoo.ca
any helps will be appreciated.
  • Ike2 Feb 07, 2008
    I was given a HItachi 46F500 projection by a friend last year and now suddenly the convergence is out on all the colors and can't be adjusted. The Vcc on the 3 STK's at pin 10 is 27V and the STK three outputs on my Fluke read around 2 Volts AC at 33Khz.
    There are 2 grey tiny Spark Gap discharge at the underside of the board below the convergence section - 1 of which reads 0.5 ohm and the other infinity.
    There is a shielded convergence box - and I was wondering if this module has a history of problems.
    I would request your help for which I would be grateful.
    Ike
    02/07/08
    ishwar700@yahoo.com
    President:
  • 4,402 Answers
If you found the burnt resisters after you replaced the ic you probably burnt the ic out again,
Posted on Jan 24, 2008
What's the value of resistor RK42 on the Hitachi 57F500A?
3.3 ohm/ 1 watt / metal oxide. HIT p/n: AT03202S -- red hor. conv. -- from IC ik04 (STK392-110/150)
May 03, 2010 | Hitachi 57F500 57" Rear Projection...
Wattage
1 watt,Service Manual I have says RK42 3.3ohms RK46 1.8ohms RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
Dec 30, 2009 | Hitachi 50FX20B 50" Rear Projection...
I have a hitachi 43FDX15B RPTV It appears to have a convergence problem, I've read about replacing the stk IC's but which resistors need to be replaced and what are the values on the DP15k/08 Board?
This model uses two of the STK-392-120 CHIPS and here are most of the usual resistors to suspect or check:
Hitachi AT03411S RK43 RESISTOR Hitachi AT03608S RP22 RESISTOR Hitachi AT03195S RK46,RK54, RK62 RESISTOR, 1.8OHM 1W Hitachi AT03857M R815,R865 RESISTOR, 1/2W 100 OHM Hitachi AT03191S RK50 RESISTOR, 1W 1.2 OHM Hitachi AT03197S RK50 RESISTOR, 1W 2.2 OHM Hitachi AT03199S RK41 RESISTOR, 2.7 OHM 1W Hitachi AT03202S RK42 RESISTOR, 3.3OHM 1W Hitachi AT03204S RK58 RESISTOR, 3.9 OHM 1 WATTThe RK ones are all marked on top and bottom of circuit board---usually if one is bad you will be able to see it is discolored---all are very low value and should read open or good only.
This is a fairly easy set to do this on---the whole convergence board (right side from the back view) is held in with 3 screws and an assortment of plugs--3 plugs are identical (convergence yokes and you need to mark so you get each back in same place)
A row of black snap plugs on the left side and with the screws and other plugs removed the board will lift up and out of the set.
DON'T waste your money on one of the "kits" being sold on the net---you can buy a pair of the chips for about 12 dollars on Ebay and usually only one (if any) of the resistors will be bad---those kits sound like a good idea but at 50-80 you are buying things you will not likely need to repair the set.
Let me know if you have any questions and if this information helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Hitachi 43FDX15B 43" Rear Projection...
I need the resistor values for RK42, RK46, RK50, RK54, RK58, RK62 when using stk392-120 chips in Hitachi 53UWX10BA.
If it is 53uwx10B:
RK42 2.2 OHM 1 WATT
RK46 1.5 OHM 1 WATT
RK50 2.2 OHM 1 WATT
RK54 1.5 OHM 1 WATT
RK58 2.7 OHM 1 WATT
RK62 1.8 OHM 1 WATT
Double check the numbers on the STK chips as most of these sets use STK-392-110 OR 392-150 CHIPS-----ONLY A FEW OTHER MODELS(MOST 43 INCH USE THE 120 CHIP.)
I do this here for free so if this helps you take just a minute and give me a vote here.
If you have any questions or need help reply to this posting here--I am here to help people.
REGARDS, SD TECH
Sep 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I need a part number or the value of rk42 and rk50
on the 53FDX20B rk42 is a 3.9 ohm 1watt resistor.
RK50 is a 2.7 ohm 1watt
Jul 15, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 51f500a,convergence out,won'adjust
RK42 is a 3.3 ohm 1watt metal film resistor
Apr 03, 2009 | Hitachi Televison & Video
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
