Question about Toshiba e-Studio 232 Black and White Copier
Pages printing with streaks.
I have a toshiba e-studio 210c , copies come out streaky around the edge and a streaky copy through the centre.The toner cartridge still has toner in it ,at least 1/3 full.help please.
Our office has one of these units that we actually called the tech to service a three week old unit because of this problem. It is a known issue by Toshiba and folks that service these units. It is also easily fixed.
You will notice when you raise the cover that there is a thin piece of glass on the left hand side that has the scanning element under it.
All you need to do is take some alcohol and clean that thin piece of glass as it tends to get smeared with ink sometimes as the pages pass over the scanning element. Look at the glass at an angle to make sure you get it clean.
Posted on Feb 25, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Posted on Jan 24, 2008
What causes streaky copies
A few questions:
- Did this problem just start?
- Was there a paper jam and when the paper was dislodged the next few sheets were streaked? Running a few more pages usually clears this.
- Is this a new toner cartridge? Did you just change the cartridge? Are you low on toner? Try removing the cartridge and gently rocking it back and forth, side to side. This will distribute the toner more evenly.
- Is this a heavier weight paper then previously used? Try going back to the old weight and see if the problem continues.
Aug 19, 2014 | Brother MFC-8860DN All-In-One Laser...
Fax copy is streaky, almost banded looking. Copies the same too, streaky looking. Toner seems to be full, drum was replaced about 10 months ago with an after market one.
If they are black streaks and they are always in the exact same place, open the cover and clean the skinny little scanning glass. It might be ink or lint. If it's white streaks then it's in the same place but it's dried correction tape or fluid, etc.
Apr 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
Streaky copies-- how to fix I jhave 3 vertical stripes of streak on every page that I print.  The toner is a new installation.  So that's not it.
This is usually a cleaning problem. Drum, fuser, rollers AND the charging wires. The wires are very fragile. Look for toner thaat is out of place.
If you are not familiar with the insides of the unit, best to take it to a shop as there are fragile things.
Dec 07, 2009 | Dell 1720dn Laser Printer
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Mar 26, 2009 | Toshiba e-Studio 232 Black and White...
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Streaky Copies
It dose not have a print head. But it dose have a drum. Are the streaks thin lines? Also, is only part of the copies fixed into the paper ( can you rub part of the copies OFF)? If you can rub off part of the copies - your problem is in the fixing unit. If the lines are fixed and can not be rubbed OFF you most likly need a new drum unit. Good Luck... Either way you will need a service rep. out to fix your problem
Oct 07, 2008 | Canon imageRUNNER 2200
Toshiba estudio 210c
toner missing on that side of developper ( where toner is stored to go on paper) or drum
Sep 01, 2008 | Toshiba e-Studio 232 Black and White...
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Toshiba e-Studio 232 Black and White Copier Logo
214 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
