Question about Samsung DLP HL-P5663W 56" TV
Finding and cleaning ventilation hole
Help
  • DGajre777 Feb 11, 2009
    Manual did not help. Where is the ventilation hole?
    Genius:
  • 1,665 Answers
Download user manual from url below. It may contain usefull info.
http://www.retrevo.com/s/Samsung-HL-P5663W-TVs-review-manual/id/276bh036/t/1-2/
Posted on Jan 24, 2008
Ac fan motor runs but get hot and shuts off
It may be dusty. If you open the computer, see if there is dust on the palms. Plus, keep your pc ventilation holes clean, and not facing walls (keep a distance).
Let me know if it helped.
Thank you!
Nov 03, 2013 | Computers & Internet
Today my computer froze and I had to turn it off. When I turned it back on just the screen where it says "e" came on and it wouldn't go any further. I unplugged it and still nothing. What...
The first thing I look at when dealing with an eMachines desktop computer, is to see;
1) If it is dirty inside.
If the cooling system is clogged up with 'Gunk' the Processor will overheat. Too many times of this causes major problems.
Air is drawn into the front of the computer, and expelled out of the back. The air flow cools the computer hardware components inside the computer.
Hardware components such as the Processor, graphics chipset, motherboard chipset, Ram Memory, and Power Supply.
If the cooling system is clogged, the cooling capacity drops tremendously.
Computer on a table, computer unplugged from power, computer case open.
Observe Anti-Static Precautions.
[Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open, TOUCH an unpainted surface of the metal frame.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return ]
Use a can of compressed air for computers. Attach the plastic straw provided to the nozzle. Break the plastic lock tab off of the top of the nozzle. (Used for shipping)
Place the straw tip in the upper left corner, (Inside), and spray air across to the upper right corner.
Squeeze the trigger in all the way as you start, let go of the trigger as you reach the other side.
Drop down a space, and spray across again. (You can watch the cleaning action of the air spray, to determine what the space drop should be. It isn't critical for the spacing. Just what you determine to be best)
Keep dropping down a space, and go across in rows.
Pay special attention to the Fan sitting on the finned Heatsink, (Which sits on top of the Processor), and the finned Heatsink.
Example of an average Fan/Heatsink combo,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
Left-click on the Fan/Heatsink photo to enlarge.
The Fan's blades, center hub, and surrounding cage (Shroud) need to be clean.
I use Q-tips to stir the dust, then follow with compressed air. You don't need to remove the dust, just break the 'crust' so the air can remove it.
(Where the fan blades meet it's center hub, needs to be clean also)
The fins of the Heatsink need to be clean. In-between the fins, and on the outside of the fins.
The Power Supply is the rectangular shaped 'box' at the upper back of the computer. This is where the power cords plugs into. It has ventilation holes in it's case.
Example of an average ATX power supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4435072&CatId=1483
The side shown with ventilation holes is the outside of the Power Supply. The opposite side you'll see from inside the computer has ventilation holes also.
Hold onto the plastic straw with one hand, and the can of air with the other. Insert the tip of the plastic straw about an inch inside a top ventilation hole, on one side. (Front of Power Supply, inside the computer)
Spray air, then move to another upper ventilation hole. Now move down, and go across using the ventilation holes. Finally shoot air in the bottom ventilation holes.
Move to the Back of the Power Supply, (Outside of computer at the back), and clean the Fan, it's surrounding cage, and shoot air into the ventilation holes of the Power Supply.
When you are satisfied the computer is clean, let it set for 5 minutes or so.
Allow any moisture that may have developed from using the can of air to dissipate.
Plug the computer into power.
WAIT 1 minute. Turn the computer on.
The second thing I look at is an eMachines power supply.
eMachines are budget computers. Nothing wrong with that, but the manufacturer saved money by installing low quality power supply's.
I replace the Power Supply with a KNOWN to be good, Compatible unit, for a test.
Main problem for desktop computers is they are dirty inside.
Next in line is a bad Power Supply.
A bad Power Supply (Weak voltage rail) will cause all kinds of software problems. It isn't a software problem. It is a hardware problem.
If you state in a Comment as to the Model Number of your eMachines, I may be able to give you a link for opening the computer case. (It's on the back of the computer tower next to the Windows product key)
Regards,
joecoolvette
Aug 20, 2011 | E-Machines eMachines Desktop PC
How to make my ps3 stop freezing
direct a desk fan onto the ventilation holes while you are playing it, Its most likely an overheat issue. If it helps, you can try and clean out with compressed air.
Oct 21, 2010 | Video Game Consoles & Games
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Dec 17, 2009 | Gaggia Titanium Espresso Machine
Kenmore 90 series Hi My dryer gets very hot in a short period of time and then turns off. Not on long enough to dry any clothes. The drum and the outside of the dryer is hot. Can you help? Thanks
Please note that if the HOT AIR that the dryer crteates is restricted from exiting the dryer because of a clooged up ventilation system or lint build up in the dryer, The ELEMENT will come on very rapidly and very bright which will eventually break the element. ALSO, please check to see if the element BROKE and as it broke it touches the stack. One way to test the ventilation system = hole on the wall to wherever the air goes outside, IS TO remove the vent hose from the BACK of theDRYER and run JUST ONE normal load to see if this works better. If all is good and the dryer works better, then your ventilation system needs cleaning. IF ALL IS STILL NOT OKAY, then check the interior of dryer to clean any LINT or as stated above, check the element
Nov 12, 2009 | Washing Machines
Ac drain pluged and leaks inside pass front , how do you correct this??
hallo
in general you have to disasembly complete ventilation and clean it. It is a lot of work. I usualy fix this bit difrent: I drill a small hole (4mm) from inside the car (co driver side.bottom black plastic ventilation box). Just on oposite side where the drain is. then go inside with some hard wire and clean the drain and on the end blow some compresed air. usualy some leaves block it becouse Grand cherokee does not have cabin filter. On the end put some screw in the hole that wather will not drop in the car and you can use it if it clogs again some day.
Marko
Sep 24, 2009 | 1997 Jeep Grand Cherokee
Ventilate
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Feb 10, 2008 | Saeco Vienna Espresso Machine
Ventilate
if you have a turkey blaster fill it with water put it in the hole were the water tank goes apply pressure and open valve it should ventilate if it doesnt i once use a bicycle pump to put enought pressure to prim the pump hope you wont have to go there thanks for using fixya pierre
Jan 08, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Superautomatic esspresso machine problem
You will probably find that the small holes in the filter are blocked with grounds of a perfect plug like size.
I carefully removed the filter plates and cleaned them thoroughly on mine and all was well.
Dec 17, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Samsung DLP HL-P5663W 56" TV Logo
405 people viewed this question
Jerry Greenberg
Jerry Greenberg
