Question about Whirlpool SB160PEE Gas Single Oven
Oven not cooking evenly, outside is getting brown but inside is undercooked
Oven not baking evenly. Outside is getting brown but inside is not getting cooked. Tried leaving food in longer, the outside just gets burned but the middle remains undercooked. Tried with warming frozen mini quiches per box directions, the outside was turning brown but the middle was still cold. Same problems with cakes. I have a Whirlpool gas range/stove.
Thanks
  • 4melanie Jan 26, 2008
    Thank you!
    Thanks for the reply vest6! Is the igniter something simple enough for us to replace ourselves or should we get a repairman? If so about how much should we expect & how long does is usually take to fix it? We're in Las Vegas.
    Thank you again!!!
    Scholar:
  • 196 Answers
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Posted on Jan 26, 2008
  • Elmer Vest
    Elmer Vest Jan 26, 2008
    The price of the igniter varies at every location. You will need the model and serial number of the machine when purchasing an igniter.
    To access the igniter you need to remove the bottom panel of the oven. Open the oven door and look for screws located in the back of the panel. Remove the panel and set it aside. The next part is the deflector shield. There should be a wing nut in the center. Remove the deflector to expose the ig-niter and related parts. The igniter is located at the rear of the gas tube. Two bolts/screws hold the igniter in place. Before doing anything make sure the unit is unplugged. Once you locate the igniter, follow the wires down to where the connect into the harness. Please remember where each wire goes.
Why is my chocolate mud cake developing a hard crust whilst not cooking through. The fan oven is 140C. (gas 2 to 3) I am thinking of using the conventional oven.Would the oven shelf still need to be on...
  • Either the oven was not fully preheated before baking so it dried out a bit on the edges.
  • Or The temperature was just up to high and it baked to fast making it crisp on the outside yet not done on the inside.
  • Or there is to much batter in the pan and while the temperature is set proper there is to much batter to throughly cook.
Regards, Tony
May 05, 2011 | De Dietrich Ovens
Smoke comes out of top when cleaning oven. Oven takes way to much time to cook. Oven does not cook evenly. Items cooked in oven are burnt outside and almost raw inside.
hello jjm... these ovens have two heating elements. when one is bad they still heat but they bake way too slowly. this is the problem here. the fix is to replace the bad element but in my repair service I always replace both heating elements since when one goes the other is usually not far behind.
Apr 28, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 790.95662100 electric oven does not bake evenly. It seems to bake items until you get into the center of a cake or the center of something with mass. The same temp has previously cooked without...
Sounds like the thermostat is out of calibration. IE- you set the temp at 350, but the actual temp is only 275, resulting in undercooked food. I repair comercial restaurant equipment, and use an infra red thermometer to check actual temp in the oven, against the set temp.
Mar 27, 2011 | Kenmore 49222 Electric Single Oven
HEAT NOT EVEN IT IS HOTTER AT THE RIGHT HAND SIDE SO CAUSE COOKIES ON THE RIGHT HAND SIDE OF THE TRAY TO BE SO BROWN. CAKE DOES NOT COOK IN THE INSIDE BUT ALREADY BROWN AT THE OUTER LAYER WHEN THE DIPPING...
Sounds like your oven burner is maybe setting at a angle, out of its bracket. You can turn down the oven flame by turning the burner orifice a little bit clockwise until the flame doesn't come up around the spreader plate. Also make sure your not blocking any vents on the bottom of the oven with foil or pans.
Jan 14, 2010 | Zanussi Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Dec 30, 2007 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
1,965 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
