Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore cold spot refrigerator freezer
I have a Kenmore Cold Spot refrigerator freezer #59592990. When you open up the front doors the lights come on, but neither the refrigerator or the freezer get cold. Any suggestions?
  • Anonymous Sep 05, 2008
    None
  • Anonymous Mar 15, 2014
    I was cleaning refrigerator and left door open too long. Light is out and hasnt come back on. Im not sure if refrigerator is cold either
  • 770 Answers
Wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
6ya staff
SOURCE:
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I have a kenmore cold spot 72102100. The freezer and refrigerator are not cold and if I touch the top of the refrigerator or if I open the freezer door and top the area where the door sits it is very hot....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 13, 2011 | Kenmore 65812
We have the Kenmore model #795.78309.800 and the freezer drawer track keeps freezing up and make it almost impossible to open the freezer. This just started the other day.
the most common problem is a bad sealing door ,when the door is closed it is not supposed to let warm air in and cold air out ,but if the seal is faulty then the opposite happens and this causes the build up of ice,take a good look at the door seal a good way of finding out if this is the problem is to run your fingers around the seal when the door is closed for a while if faulty you will find a warm spot where the cold and warm mix causing a warm spot.adrian,,,,,,,,,,
Aug 13, 2010 | Kenmore 22.4 cu. ft. Bottom Freezer...
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Jul 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore cold spot not cooling properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
658 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
