Question about Samsung TXJ2768 27" TV
Txj2768 vertical problem
I have a vertical problem the top of the screen is fin the bottom half is gone checked my capacitors and changed the vertical output ic
  • af4oe2002 Jan 25, 2008
    i have my negative and positive vcc's on the chip and the input signal looks nice on a scope.
  • 579 Answers
Now check the power going into the I.C.
Lots of times it will blow the dropping resistor feeding power from the flyback.
Posted on Jan 24, 2008
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Screen gone half black...tried with different CPU...same problem persist... Please advise what to do...
The effect is called fold-over, where the bottom of the screen is folded over the top half.
If you can get into the menu set up you can try and change scan settings and adjust them so that :-
1. The screen is moved down so that the bottom of the fold-over is at the bottom of the screen and the top of the windows screen is at the top (it is missing on the photo).
2. Adjust the vertical scan rate to resolve the fold-over problem.
Otherwise it needs fixing by a TV engineer that can fix monitors as the adjustments are inside.
Mar 19, 2015 | Computers & Internet
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
Hi I have a Philips 36PW9525/05 CRT TV. The sound is fine but the top half of the screen is not visable the bottom half seems fine. Can you advise on a fix??
hello sir i already encounter that problem..first remove the cover of your unit then you go to the vertical section of CRT driver when you see the I C that stand vertically it means that section is vertical then if found that section you have to do now is look for leak/bulged top capacitor near the vertical I C then replace with the same value/rate thank you sir
Mar 05, 2011 | Televison & Video
The top half of my screen is black, the bottom half shows the "top half" of the picutre.
Hi there.
It sounds like a vertical problem. And by the description you`ve given it might be caused by bad capacitors in the vertical deflection circuit.
Hope this help Merry Christmas
Dec 19, 2009 | Televison & Video
Menu not in centre of screen and unable to see volume bar
1. Solder the vertical IC. & IC supply capacitor.
2. change the vertical IC
Oct 20, 2008 | Samsung SyncMaster 1200 NF (Ivory) 22" CRT...
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Samsung TXJ2768 27" TV Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
