turn of your psp 1.turn on the psp by holding the (R trigger) you will be in the recovery menu 2.scroll down to CPU SPEED and change the xmb to default and game to default this should work
Note: only for version 5.03 GEN-BStep 1: go to restore default settings, psp will restart
Step 2: go to themes, change the color to white
Step 3: This is the tricky part... go to photos and press down(don't let go) then press x.., your psp suddenly crushes and restarts
Step 4: run the 2 programs on the game folder ... CFWenabler then the 5.03 GEN-B Updater.... Your welcome...
Backup up your games on a PC. Then Format your memory stick and put the psp games back in the memory stick if this does not work try formatting your psp by entering the recovery mode HOLD R + HOLD POWER... Go to advanced/advanced config/format flash 1 and reset settings
if this also fails try using another memory stick on your psp
Did you mess with the flash0 or install a new firmware or theme? If you did then you probably just need to go back to the one previous. First check another umd to make sure.
