Question about Intel D865GBF Motherboard
My display monitor run 4 bit colour only
How
  • metsciences May 11, 2010
    I was removing unused programs and somehow I removed something theat caused mydisplay color to drop to 4 bit. I have tried to change back to the 16 bit, but there is no response.I'm running MS XP, service pack 3.
My display colour only 4 bit i want to 16 bit or 24 bit solution
Posted on Jun 18, 2008
    Genius:
  • 1,067 Answers
Do u have video card d driver installlede
Posted on Jan 24, 2008
Hanks
Posted on Aug 26, 2008
2 Suggested Answers
lsteward68
  • 331 Answers
SOURCE: there is no colour on my monitor.. It is running
Hi Khan your motherboard is a Biostar. you will need to get the drivers from biostar or we can search Intel's website
http://www.biostar.com.tw/app/en-us/mb/content.php?S_ID=234
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=234
Let me know if this helped
Posted on Jul 05, 2009
My monitor is not displaying colours.... its only showing bit of blue and yellow colour.... please give me solution.....
CRT monitors can fade over time. try resetting factory settings and degaussing, if you have that option. If not, you need a new monitor. Buy an lcd.
Feb 18, 2011 | HP mx705 17" CRT Monitor
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
My monitor has a variety of colors going down the left side of the screen and across the top of the screen
increase colour quality 24 or 32 bit from display properties, if there are no options than u have to install display driver.
Aug 02, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
My computer is a compaq nx7010 and i got 4 lines on the right side of my screen.3 of them are red and they change there colour with different background.
all u need to do is u need to run the diagnostic on ur laptop which will check the colour display and then restart the computer and then still if it is there check it with the different external monitor and if u get the same line in the external display also then replace the graphics card and if u do not see the lines in the external monitor then u need to replace the lcd screen.good luck take care.....
Dec 22, 2008 | Compaq Presario M2000 Notebook
MOnitor Display
1. cheak the display cable.
2. Solder the dry points on the neck board.
Dec 19, 2008 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Need help about screen resoulution....
Try out these simple steps
1. download latest graphic drivers of your graphic card
2. orchange your monitor refresh rate to minimum like 60 HZ
Mar 03, 2008 | Iolo Technologies System Mechanic 5...
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Intel D865GBF Motherboard Logo
1,503 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
