Sony VCR rewind and counter problem
I have a Sony SLV-N51 VCR which has always worked perfectly until this week when it is having trouble rewinding. It takes a VERY long time to rewind, and the counter sometimes sticks. After rewinding from 1:59 to the very beginning, the counter was stuck at 1:38. It seems to record and play just fine, and fast forward still work, though I think it's slower than it used to be, and I'm baffled. I've used this VCR nearly every day for at least 5 years, so maybe it's just given up, but since it's so hard to find a simple VHS machine these days, I hate to have to toss it. Any ideas?
  • 579 Answers
The belts are slipping. Every 5 years is about right for replacing them all.
Posted on Jan 24, 2008
I have a Sony VCR. Model SLV-N51. I record a lot of television shows on new Sony VHS tapes and when I play back the tape the picture scrambles every so often. When I rewind it back to where the...
First of all I want you to check the tape inside it's case as soon as the problem occurs. Stop it and eject. You'll find a button on the side of the VHS tape, press it and you should be able to lift the flap. Look at the tape it should be smooth and shiny. If it is there's nothing causing damage. If you see any damage then the mechnism is causing it.
If that is good (which I think it will be) I want you to take off the top cover of the VCR and with some Servisol Video 40 spray, blast all the surfaces that the tape comes into contact with. You can wipe them too with cotton buds. Give the heads special attention. Once done leave for 30 mins and try it out.
I think the problem might be dirt that the head cleaner tape couldn't shift. The sound dipping being the hi-fi sound dropping out reverting back to the mono sound head. When you rewind the video tape acts like a cloth for an instance, hence the better performance.
Sep 11, 2010 | Sony Televison & Video
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
Unit was dropped but works ok except for rewind function
Not worth repair,VCR very cheap these day.Gear under parts,probably can't put it back,must take alot of parts aparts.
Nov 22, 2009 | Sony SLV-679HF VHS VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-N60 stopped playing suddenly
Sounds like you have a head-clog. You can purchase a VHS Head Cleaner at Radio Shack for $5.00. If that doesn't work repairing your VCR is not cost effective when you consider that you can purchase a new VHS/DVD combo deck for under $125.00
Aug 17, 2009 | Sony SLV-N60 VHS VCR
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
