Belt slipped off
If it's the diagram you're looking for, click on the link below and enter your engine size. You will be directed to a page that has a Belt Routing Diagram. Select the appropriate one (some Caravans do not have AC) and you will receive the diagram for your vehicle.
1998 Dodge Caravan Serpentine Belt Diagram
SOURCE: Serpentine belt slipped off. I need a diagram
How's this.
Testimonial: "Awesome. Thats the one I thought it was, can't get it to move though on account I can't get a wrench on it. theres no room to get my hands in there!"
SOURCE: Serpentine belt slipped off. 1998 Dodge Gran
On this particular model of the 1998 Dodge Grand Caravan I determined that the upper hose from the water pump had slipped off and anti-freeze squirted on the serpentine belt causing it to slip off. Once the belt gets slick it never stays on. I replaced the belt by loosing the tensioner which is the idler pulley located in the center of the configuration, A big thanks to user motor1258for the configuration diagram.
SOURCE: serpentine belt replacement
What engine do you have? The 3.3 and 3.8 engines have a single serpentine belt, and a belt tensioner, so no adjustment is needed. Did you replace the tensioner, and want to know how much to torque it? countrycurt0
SOURCE: I need a 1998 Dodge Grand Caravan serpentine belt diagram.
The belt routing diagram is shown on a decal located on thehorizontal metal support above the radiator and under the hood support rod (passenger's side near the coolant overflow tank).
PT Stanley
SOURCE: serpentine belt for Dodge Caravan 1998, it repair
Go to auto zone rent a special tool used to release tension on the serpentine belt tensioner.
It's located on the left side looking at the engine from teh front,
You may not have a lot of room to fully pull back the tensioner SO have some ratchets ready and some sockets and a small pipe for leverage, it's a bear.
Your tensioner MAY be bad so you may have to replace it.
Fig. Fig. 11: Accessory drive belt adjustment-3.3L and 3.8L engines
All of the belt driven accessories on the 3.3L and 3.8L engines are driven by a single serpentine belt. The belt tension is maintained by am automatic tensioner.
