Question about Jenn-Air JJW7530DDS Electric Single Oven
Crumb Catching Design
The curved front of the oven extends past a standard countertop. This causes spills and crumbs to fall and be caught by the protrusion
  • Gary Davd
    Gary Davd May 11, 2010
    dont put cumbs on the counter
    Scholar:
  • 196 Answers
Yes, this design catches all knids of things but it keeps those "crumbs" from getting inside the door facing. This also acts as an air relief for the oven.
Posted on Jan 26, 2008
6ya staff
SOURCE:
Oven door falls
jenn air wall oven
dont like the design of the hinge itself
door section has to be locked in ..
but by the design of the door capture sure looks like
the door can be removed for easier cleaning
Jun 18, 2016 | Jenn-Air Ovens
How do i place the oven racks back in
If you look at the rails on the sides of the oven, they should have a little jig or curve about 1/4 of the way back from the front. Hold the rack with the little curved end toward the back of the oven and have the front of it several inches higher than the back of it. Select the slot where you want it to go and start feeding the rack into the oven, as soon as the back of the rack passes the little jig in the side rail, you will be forced to let the front of the rack down level with the back and then you can slide it the rest of the way in. Hopefully this helps!
Nov 23, 2010 | Kenmore 47782 / 47784 / 47789 Electric...
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
I bought a used 27" Thermadore double oven off Craigslist. (Loves me some Craigslist.) SS, convection, electric. Sticker on side indicates it was manufactured in 2001. I can't find the tag with model...
If Thermador kept the tag information in the same place, look at the bottom of or just below the control panel (front left hand side of the control panel (when facing the oven) where the cabinet curves).
The oven cleaners can damage the finish and parts of the self-clean oven. The damage may cause the oven to fail sooner than it would otherwise.
If you have a small spill that you want to clean without using the self-clean cycle, on a painted surface, use soapy water or Fantastick or Formula 409 applied to a clean sponge or paper towel and then wipe clean. If the spill is on a porcelain surface, wait until the oven is cool and use Bon-Ami or Soft Scrub on a clean sponge. Then rinse clean. For stubborn dirt, use a soap filled pad.
I hope this helps.
(Thermador has manuals on their website: http://www.thermador.com/SupportCenter/DocumentDisplay.aspx?menu_id=27&menulevel=0302&cat_id=687 )
Aug 05, 2010 | Ovens
When i use the oven it stays hot after turned off. front panel, right under the touch buttons gets very hot.
This oven has an oven vent that comes out under the control panel usually to the right. Very poor design as this vents heat into the controls and can cause a control board failure, especially during a self cleaning cycle. Good Luck, Appliance Specialists
Dec 14, 2009 | Amana AEW3530DD Electric Single Oven
I have both a tornado and a C3. I am getting a F2
for the f2 low temp verify the high-limit thermostat is not tripped. inspect the mags, make sure they are not loose. Also try inspecting the ir element washer look for corrosion or signs of arching. Is your wave cover damaged or missing. Sorry to say this generally is a factory trained fix because its usually because of an rf leak
Oct 09, 2009 | TurboChef TORNADO Electric Oven
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Filling in the gaps between the kitchen counter sides and stove
Stove Buddy crumb bumper makes a black one that is a heavy duty non metal-can handle 500 F but is not cheap like the kleen seam--
Feb 18, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Dec 12, 2008 | Jenn-Air Electric Double Oven
Jenn-Air JJW7530DDS Electric Single Oven Logo
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
