Question about Brother MFC-5860CN InkJet Printer
Brother mfc 5860cn
How do i access the ink cartridges to change them, i am technically inept, no manual
  • Anonymous Mar 14, 2014
    how to replace a pickup assembly for a brother mfc 5860cn
  • 832 Answers
On the right hand side seeing from the front (where you put in the paper tray) is a clap. within are four colored latches. each of them have to be switched down to open:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_009.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Posted on Jan 24, 2008
I have cleared the paper but it still says paper jam?
Posted on Oct 17, 2010
Mfc 5860cn not printing red
Did you try replacing the color ink cartridge?
Mar 24, 2013 | Brother MFC-5860CN InkJet Printer
Brother MFC-5860CN printing issues after switch Win2k to WinXP
Are the settings in the print driver set to the highest quality setting? If so, this will slow the print speed down tremendously. Try changing the default settings in the print driver to a lower quality (or resolution) setting.
Dec 20, 2009 | Brother MFC-5860CN InkJet Printer
Dont' Know Where Printer Cartridges Go In Brother MFC Printer
Here is the manual:
MFC240c Manual
See page 93 for ink cartridge replacement.
Thanks for using Fixya.
Jun 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 03, 2009 | Brother MFC-5860CN InkJet Printer
Ink cartridge
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Brother Multi-Function Center MFC-5860CN...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-5860CN
On the right hand side, on the front of the printer, next to the top paper tray. There's a plastic piece that comes free and the four cartridges are inside there.
Jul 02, 2008 | Brother MFC-5860CN InkJet Printer
Brother MFC-5860CN InkJet Printer Logo
334 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
