Question about Singer 5160 Mechanical Sewing Machine
Singer 4325C jammed
My 90 year old aunt went to sew the other day and the machine made three stitches and jammed. I took the top off and could see nothing inside that could cause this. I did take the belt off and the motor turns freely. I lubricated everything I could get to and it still has what feels like a brake engaging when turning the wheel by hand. This happened suddenly as the machine has worked properly up until this last attempt to use it. I can turn the wheel past this and it will move freely for a stitch or two then the brake kicks in again. We live in a small town miles from a repair center and it would do my heart good to be able to repair this for the dear old gal. The only model number I could find was 4325C which is not listed in your selections. Thanks for your help.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 43 Answers
SOURCE: reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
Posted on May 08, 2009
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
SOURCE: singer handheld quick stitch instruction manual
find it here:
Posted on Jul 04, 2010
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I have the Singer Touch Tronic 2001. I bought it used for $50. It has the manual and all the parts. However, the manual refers to lifting the top console to access the stitch width selector dial and to change the pattern selector discs. I cannot seem to lift this console up even the manual says that it is hinged for easy access to these parts. Can anyone describe how to lift the console up? Or send a picture or video of this process?
Most appreciated!
Posted on Aug 09, 2010
0 characters
1 Points
I have a Singer sewing machine model 9117. Every time I use the zig zag stitch the machine jams and I cannot continue sewing. Any ideas?
try a new needle
make sure the top thread has not come off the thread take up lever
there could be something wrong with the cam that does the zig zag stitch, if the problem continues you may need to have the machine checked
Apr 07, 2016 | Singer Sewing Machines
The bobbin case is completely moving around and jams up the machine. This has happeded three times in the last two days. How can I get this to stop?
I don't know the Make, and model of your machine, but the stitch finger isn't keeping the bobbin case still. It's either loose, or missing.
Mar 02, 2015 | Singer Sewing Machines
Singer 27
What kind of thread are you using. The most often problem today is that the thread is too thick for the size of needle. Try using a Metallica size 90 or a top stitching needle size 90
if the thread is a cotton type or a quilting thread it is often to thick to travel easily through the eye of a needle quickly to form a good stitch.
Aug 03, 2014 | Singer Sewing Machines
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
I have a simple singer 2263. I have now realized I had it threaded wrong, but ended up with a large jam in the bobbin/shuttle area. I removed the shuttle - any pictures or instruction on how to replace?...
Oddly, this came up when i googled" troubleshoot singer 2263". but since I'm here...
This expenxive knick knack is a joke, except it's not funny.
We should get Michael Moore to make a movie. Singer sould be ashamed of themselves. The brand our grand & great grandmother's ached for & 90% of could not manage to purchase.
What with pandemics, wars & depression (not the type treated by Celebrex)
I got 1 for Christmas, YAY (I thought)
It worked exactly 92 days, (warranty is 90, & parts only)
Singer (who do not deserve to have their name capatalized) said take it to a singer dealer, ($80.00 to look @ , machine cost $90.00, later saw it on sale for $68.73).
The vendor did exchange it,
I took this exact replacement home, set it up, never sewed 1 stitch.
The bobbin thread was wrapping around the spool pin.
The box was gone, the receipt inside.
I took it back the next day. Vendor would not exchange.
So I''m going in...this was not my plan.
If I can't get it, I'm going to small claims court, as I do have proof of purchase on per my credit card.
I'll be back!
Oct 05, 2009 | Singer 3116 Simple
I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Aug 16, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Reverse stitching on a singer 514, HELP!
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 5160 Mechanical Sewing Machine Logo
277 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
